12-19-2017, 02:24 PM | #1 | |
Starter Issues HELP!!!
SO THIS IS THE SECOND STARTER THAT HAS BEEN INSTALLED ON MY 16 SS. NOW, THIS STARTER IS STARTING TO DO THE SAME THING AS MY FIRST ONE DID AFTER 2 MONTHS OF RUNNING GREAT. WHEN THE NEW STARTER WAS INSTALLED MY CAR WOULD CRANK UP IN NO TIME HALF A SECOND NOW IT TAKES ABOUT 2, HAVE YOU ALL EXPERIENCED THIS ISSUE WITH YOUR CARS AND IF YOU HAVE WHAT SHOULD I DO. I REMEMBER HAVING THIS DISCUSSION A WHILE BACK AND SOMEONE SAID I SHOULD WRAP MY STARTER IN THIS SORT OF HEAT BLOCKING WRAP BUT WHO KNOWS I COULD REALLY USE YOUR HELP! ON THE VIDEO LINK SKIP TO 4:15 SECONDS TO HEAR THE ISSUE IM HAVING.
12-19-2017, 02:36 PM | #2 |
Drives: 2017 2lt rs Join Date: May 2017
Have battery load tested. Also a starter draw test
12-19-2017, 02:58 PM | #3 |
Drives: 2016 Camaro 1SS Red Hot Join Date: Sep 2015
I had same issue. Would only happen on hot days after driving hard and then shutting car down and trying to restart shortly after, like within 5-10 minutes. Starter finally toasted itself about three months ago. Starter was replaced under warranty and haven't had any issues since, but I haven't driven it hard on a hot day yet to see if it will do it again.
Red Hot 1SS
MRC NPP Black Bow Ties Black Metallic Rally Stripes Black Wheels With Red Outline TPW 12/14/15 1G1FE1R72G0133041 - 12/16 built 2/19/16 - It's mine!! Previous rides: 2011 Camaro LS 2010 Camaro SS 1988 Honda Civic Hatch B18C1 swap |
12-19-2017, 03:03 PM | #4 |
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
http://www.camaro6.com/forums/showthread.php?t=430867
I'm not watching the video, but 2s sounds like it's in a normal range depending on ambient conditions. Reference link.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
12-19-2017, 03:18 PM | #5 |
Drives: 2016 Z06 coupe Join Date: Dec 2016
Direct injection cars take longer than those older systems to start.
12-19-2017, 03:46 PM | #6 |
trust me its not normal.
12-19-2017, 04:25 PM | #7 |
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C) Join Date: Jun 2017
Yeah definitely not normal, I mean my car here and there starts a little late but never sounded like that. Spark plugs good? Plug wires good? Any cuts in the ground connected to the starter? I had an issue when I installed my headers that the heat shield touched the negative cable which caused some issues but after re aligning it correctly the second time all is well.
12-19-2017, 05:43 PM | #8 |
Drives: 2016 Camaro 1SS Join Date: Aug 2016
Starter
Is the engine cranking slowly? Or does it sound normal just taking longer to start? Mine always start slow when hot and I let it sit for about 10 minutes. Some on here think it is normal to start slowly when hot. This is never a normal condition. I am taking mine to the dealer for the second time and they will fix the problem. It is ridiculous that a modern car would do this.
12-19-2017, 05:58 PM | #9 |
Yeah mine only does this when it’s hot and I live in Florida so I can’t keep having this issue.
12-19-2017, 05:59 PM | #10 |
I asked Chevy to check all of this and they just replaced that starter and the car drink up very fast for about 2 months then the delayed start started happening again.
12-20-2017, 07:02 PM | #11 |
Drives: Chevrolet Camaro SS Join Date: Mar 2015
It cranks but doesn't start for a period is not a starter issue, it's another
And don't use upper case, you're yelling at us |
12-21-2017, 11:40 AM | #12 |
The Milano
Drives: 2017 Firefly ShipWorks Join Date: Jun 2010
Sounds like a low battery condition. Not enough cranking amps.
My first Love. She was called "Miss Carriage" (still cry when I think about her)
383, Muncie 4 speed, custom linkage mated to hurst short throw shifter. |
12-21-2017, 12:18 PM | #13 |
Drives: '20 ZL1 M6 Join Date: Apr 2017
Please clarify. Does the starter run at normal speed and it just takes the engine longer to start, or is the starter cranking slower than normal? Mine cranks fine, but takes a second or so for the engine to start. That would seem normal to me.
Mal
Ft. Lauderdale, FL '20 Camaro ZL1 M6 '22 Kawasaki ZX-14R |
12-21-2017, 12:43 PM | #14 |
Drives: 17 Fifty SS, 11 2SS, 91 LSX C1500 Join Date: Apr 2013
In the video he links it is turning over really slow, like it has a weak battery. Definitely not the normal cranking delay.
Tags |
starter |
