12-27-2017, 07:27 PM | #1 |
Drives: 2012 Camaro SS Join Date: Oct 2016
Cipher Harness bar question
Hey all,
Got a Cipher Harness bar for Christmas. Got it installed and looks great. Having an issue though with the factory belts retracting properly. They are in front on the bar as per the instructions but are having a hard time retracting. Any tricks to get them to work properly? Thanks |
12-28-2017, 01:07 AM | #2 |
Emerald Coast Camaros
Drives: 2013 2SS/RS L99 Join Date: Dec 2013
Cipher bar
Interested to see what the outcome is on your install. I wanted to install a cipher harness bar for autox events but retain the factory belt system the other times. Post up pics and let us know what you think of the setup when the bugs are worked out. I even looked at the BK version but after researching SCCA rules, i can't run this harness bar setup and remain in Street Class.
12-28-2017, 04:13 AM | #3 |
Drives: 2010 Camaro Join Date: May 2014
Wish I could help. I use this bar, but run harnesses full time. (Not a DD). I just find them more comfortable and secure than a stock seat belt.
12-30-2017, 11:05 AM | #4 |
Thanks I'll try and get some pics up to help trouble shoot. I'm waiting on tank plates to come it for my belts to be fully operational. Its definitely annoying having to fish the stock belt slack back down by hand when you get out.
12-30-2017, 01:04 PM | #5 |
How much play is in your bar once you have everything tightened down?
12-30-2017, 03:43 PM | #6 |
Drives: 2010 CAMARO SS Join Date: Apr 2010
I removed my rear seat belts because I made a rear seat delete set-up.
here are a few pics |
12-31-2017, 07:28 AM | #7 |
Drives: 2023 Camaro ZL1 1LE Join Date: Feb 2016
Sorry I can't help with the belt issue, but man your setup is AWESOME!!!! So clean! Those seats Do you have anymore pics??
2014 Camaro SS Spring Edition LSX440ci
LSX Block, MAST 305 Black Labels, Exceldyne Valves, Diamond Pistons, Callies Crank & Rods, Cam Motion Cam, Johnson 2116LSR Lifters, Comp XDA Pushrods, Jesel Rockers, Mamo MSD, NW 102, Roto-Fab CAI, FAST 65# Injectors, ZL1 Fuel Pump, Kooks 2" Headers, Corsa Sport 3" Catback, Z28 Shifter, ZR1 Clutch, Katech LW Flywheel, 1LE 3.91 Diff, LPW Diff Cover, BMR - 1.4" Springs, LCA's, Trailing Arms, Toe Rods, Sway Bars, End Links, Diff Bushings, and Tunnel Brace, Z28/1LE Strut Tower Brace, Improved Racing Oil Cooler 2023 Camaro ZL1 / 1LE Stock |
12-31-2017, 08:07 AM | #8 |
thanks !! they are from cipher 675 for both , planted brand seat mounts 300.
12-31-2017, 08:12 AM | #9 |
Not a bad price at all. Whats your impression of them so far?
12-31-2017, 10:45 AM | #10 | |
No real play in it its solid once cranked down and support rods tight. My install matches the install instructions picture but its like the belts are getting pushed to the front of the plastic where the retractors are and keeps it from retracting back in unless you use your fingers to guide it in better. |
12-31-2017, 10:49 AM | #11 | |
Nice setup I should of gone with that bar setup. The Cipher bar one I have mounts to the top seat belt mounting bolts and has the two supports coming down to the lower seat belt bolt by the door. Also causes the bar to rub against back of stock seat when back a ways. Being 6'5" its back all the way normally. |
12-31-2017, 12:05 PM | #12 |
12-31-2017, 12:07 PM | #13 | |
