02-02-2018, 12:48 AM | #1 |
Donkey Dick Cam Camaro
Drives: 2010 2SS/RS LS3 M6 Join Date: Oct 2009
i cant wait for march 26th
cold starts! cam is a comin' soon!
Bone Stock |
02-02-2018, 12:54 AM | #2 |
Drives: 13' 1LE Join Date: Apr 2012
Nice move son
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
02-02-2018, 01:01 AM | #3 |
got everything installed on the driveline in order to be able to put the added power to the ground better.
bmr trailing arms and toe rods complete Z28 hellical diff with 3.91 gears 1LE CV axles and new rear hubs last thing is the cam can hardly wait now!!!
Bone Stock |
02-02-2018, 03:39 AM | #4 |
Drives: Camaro and Sierra Join Date: Jul 2012
Which cam you go with?
02-02-2018, 07:35 AM | #5 |
Drives: 2013 Camaro SS Join Date: Oct 2016
02-02-2018, 08:46 AM | #6 |
02-02-2018, 03:16 PM | #7 |
That pic is so damned funny.
I am not even cammed yet and that's already how things are in my neighborhood.
2010 CGM Camaro 2SS LS3 Swapped A6 - GPI LS3 SS1 .647/.638, (224/237, 112 +4, 7Ί overlap) on CamMotion 8620 core, BTR Platinum .660" Dual Spring kit w/titanium retainers, CHE bronze trunnion upgrade, stock heads milled @ .015, Melling HV 10296 oil pump, TSP 1-7/8" long tube headers (W/Catless Off-road Pipes), Corsa Xtreme 3" Catback, GPI Ported/Rod Mod Intake, Stage 2 Ported Throttle Body, Vararam OTR CAI, Mike Norris Gen 2 catch can + GM 1LE clean side separator, 160Ί thermostat - Megan Racing adjustable coilovers (lowered 1.75"), MRR M017 10/11" wheels-Tuned by Ryan @ GPI
02-02-2018, 04:18 PM | #8 |
Lmao Borrowing that one if you dont mind Glad got great Neighbors but dont know how they will act when it comes back home Whining big time with a Big Red Race BOV 🙂👍
'11 IBM 2SS/RS Built and Tuned by Vengeance Racing Vengeance PCM
Vengeance Racing Mast Black Label LS7 Headed 416 ProCharger Stage II D1X Race ,Monster Triple,Alky Control Meth Inj, Forgestar F14 Drag Version and a bunch of other blah blah blah.838/688 at 12lbs Street Friendly |
02-05-2018, 04:50 PM | #9 |
its a custom grind by cunningham motorsports using a cam motion 8620 core.
23x/24x duration 11x is what ive been told ....... if i get my tax return in time, im also getting some trick flow specialties GenX 255 12 degree heads. bo white's car with the 13 degree heads and another build ive watched with Gwatney Performance's 12 degree heads conviced me that i should get the heads now if i can afford them. the factory heads are coming off when i get the cam installed since im getting new lifters installed with it. so if i get that tax return in time, id like to get put back together with some 12 degree heads and hopefully close to 510ish RWHP and 460ish RWTQ on 91 octane pump gas. (im in california so thats all we have)
Bone Stock Last edited by sixty9fordkiller; 02-05-2018 at 05:00 PM. |
02-05-2018, 04:58 PM | #10 | |
its the same setup this guy has
Bone Stock |
02-05-2018, 05:01 PM | #11 |
Drives: Savitar; The 500rwhp N/A Monster! Join Date: Aug 2016
Nice! I really want to start building the rear better but can never convince myself to do it when the money finally allows haha.
*SOLD*504HP/433TQ | Night Fury cammed Cold Air Inductions intake Bo White ported TB Speed Engineering 1 7/8 longtubes NPP catback QTP low profile cutouts Powerbond 25% UDP 3.73 gears JRE scoop ZL1 grille R1 Concepts drilled/slotted rotors built/tuned by Weapon X Motorsports
02-05-2018, 05:11 PM | #12 | |
as far as the rear upgrades i did, i can honestly say that the one thing i should have done to the car long ago was the 3.91 gears. its just stupid how nimble it feels now off the line. not sure if the 1LE CV axles also helped or if it was the BMR trailing arms and toe links, or the 335 30 20 MPSS tires i have or a combination of all, but the car feels like it can really lay the power down now and thats why im confident that im ready for the cam and heads. the only thing i sometimes question is whether i should've done the solid cradle bushings when they lowered the rear cradle in order to install the toe links (the driver side bolt that holds the toe link to the cradle will not come out unless the cradle is lowered) I dont road race or drag race it and dont beat on it hard in that sense. I daily drive it and enjoy it early in the weekend mornings on the open freeway and will likely do some ShiftSector 1/2 mile racing from time to time. That type of racing doesnt tax the differential or axles like drag racing does and that ultimately made me pass on the solid bushings.......for now one thing is for sure though: You should convince yourself and get the 3.91's. you will love them
Bone Stock Last edited by sixty9fordkiller; 02-05-2018 at 05:25 PM. |
02-05-2018, 06:08 PM | #13 | |
Drives: 2010 Camaro 2SS/RS ABM 6M Join Date: Jul 2017
Even in mostly stock trim it feels pretty weak down low. I am worried the cam/heads I'm in process of doing now are just going to make worse. Gears are most likely my next mod after I recoup from all the current parts Also, love the pic in the og post. Gonna steal that for Facebook so my neighbors can be warned haha
2010 ABM 2SS/RS LS3 6 Speed -- Rotofab CAI | Speed Engineering 1 7/8" Longtubes w/ cat Delete | Magnaflow competition catback | TSP 231/246 cam| TSP/PAC .660" Spring Kit | TSP CNC Ported Heads | Bo White PTB | GPI Ported/RM Intake | 3.91's | BC Catch Can | MGW Shifter | BMR 1" Drop Springs | BMR Trailing arms/Toe Rods/Rear UCA Bushings | Pegasus Subframe Mounts
02-05-2018, 06:43 PM | #14 | |
