03-06-2018, 09:35 AM | #1 |
Drives: Yellow 2014 2SS Convertible Join Date: Oct 2016
How do I remove the X1 harness from the factory BA amp?
I have a 2014 Camaro 2SS with the BA sound system. I'm trying to use the ******** FARK harness to put my own amps, and as part of the process am removing the factory BA amp.
The X2 and X3 harnesses were easy to remove; each had a clip on top that when depressed unlocked the harness so I could pull it out. The X1 harness has what looks like a more complicated clip (I see red and white). Depressing it does not appear to unlock the harness. I've grabbed it with a set of pliers and pulled as hard as I dare without risking damage, but since it's seated I can't get a grip on the harness itself and have to apply force via the wires. Is there something special I need to do to release this harness? I ran into a few harnesses in the door panels that worked in strange ways too, and I can't seem to find any technical information from GM on this stuff. In a worst case scenario could I safely clip these wires and cap them? Any help or suggestions would be appreciated. |
03-06-2018, 02:48 PM | #2 |
Drives: 2011 2SS/RS Join Date: Feb 2016
Should just be the big clip.
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels •Vararam Ram Air Intake •Speed Engineering Longtube Headers w/ Magnaflow HF Cats •Bo White PnP Stage 2 TB •GPI SS2 VVT Cam w Cometic thin gaskets 10.69 compression •Xpipe w/ Res Delete and NPP Exhaust •Tuned By Anonymous Calibrations •Gen5DIY Mylink Conversion W/ Backup Cam •Morel 3 way custom speakers, Infinity 860w Subwoofers in trunk baffle •Helix P6 6ch amp w/ 8ch DSP and P1 Sub amp |
03-06-2018, 05:10 PM | #3 |
Thanks. I managed to get it out with a very large pair of pliers and a lot of force. I think the plug part of the harness is toast now, but I should hopefully never need it again. At least the amp connector seems okay.
03-06-2018, 07:38 PM | #4 |
Drives: 2011 Camaro 2SS/RS Join Date: Oct 2013
That connector is actually very easy to remove with very little force. Shouldn't of had to use pliers or break it. When I was back there tapping the wires to add an aftermarket sub amp, I used my fingers to unplug it.
03-07-2018, 08:02 AM | #5 |
Yeah, I think something was wrong with mine. I started at X3 and got X3 and X2 out with my fingers without a problem. I expected X1 to slide right out too. What followed was 30 minutes of aggravation...
