03-17-2018, 12:25 AM | #1 |
Drives: 2011 Camaro SS Join Date: Feb 2017
Mustang Dyno
Good or bad? What’s the deal?
MRR M228 Wheels, Circle D 3200 Stall, 3.91 Gear, Texas Speed VVT 3.2 Cam, CHE Rocker Arm Bushings, Texas Speed Headers, No Cats |
03-17-2018, 01:52 AM | #2 |
Drives: Camaro and Sierra Join Date: Jul 2012
Well it's not a camaro Dyno...
Good or bad in what way? |
03-17-2018, 01:52 AM | #3 |
Drives: 20’ Chevrolet Camaro 2SS 1LE Join Date: Jan 2009
03-17-2018, 09:58 PM | #4 |
Drives: 2010 Camaro 2SS Victory Red 6M Join Date: Apr 2015
They are notorious for being Heartbreakers. You get 500whp on a dynojet, you MAY get 450 on a Mustang. So if you crack 500whp on a Mustang, you can bet your sweet a*s that it is legit.
2011 2SS 6A Red Jewel Metallic, Vararam Tune CAI, Magnaflow 3" Competition c/b, Speed Engineering 1-7/8 LT's, Circle D 5C, M/T 275/40R20 S/S, HPTuners tune by Ryan@GPI
12.3 @ 112 ACM as of 12/22/19 Gone on 12/28/19 R I P 2010 2SS 6M Victory Red/Black (old ride) CAI intake, Speed Engineering 1 7/8" LT's, X4 base tune, Flowmaster Outlaw axle-back. 12.6 @ 115 SAR as of 9/19/15 Gone but never forgotten. |
03-17-2018, 10:02 PM | #5 |
Ha, that’s true. I keep hearing that your hp numbers will be lower on a mustang dyno. So does that mean others are more accurate or just give higher false readings?
03-17-2018, 10:14 PM | #6 |
That’s my question, if you get 500 on dynojet and 450 on mustang which one is correct? Just had my car tuned on a mustang and got 444 hp is why I’m asking
03-17-2018, 11:45 PM | #7 |
It's all a number. tuners can change variables to make cars numbers better if they want. I made more on a mustang than a dynojet although car wasn't running correctly with a certain shop.
My buddy and I started digging into the tune and made a lot of changes, basically we started over. Fixed the tune and picked up ~20rwhp on same dynojet. Don't get to caught up in numbers. I've learned not to trust tuners as well. Even ones that seem to treated like gods on here. |
03-18-2018, 08:20 AM | #8 | |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
yes some tuners(hell complete shops) are morons when it comes to these cars...however there are some extremely competent tuners on here and unless the car owner f's it up...the tuner has worked with them...sometimes over and above board and to the extent that separate vendors have confab's to fix a prob(at no compensation to them!) they just wanted to fix the prob and make the owner happy...and he is. so just wanted to clear the air and reitterate that 1 bad apple does not make the whole barrel bad... be safe...which branch?
03-18-2018, 09:58 AM | #9 |
I'm not saying they are all bad but really have to do your research. Car is currently tuned by ryan after I installed their ss4 cam.
27 more days, Air Force. |
03-18-2018, 10:10 AM | #10 |
old school chevy rodder
You can search on the internet and the general consensus is that the Mustang being Load bearing is the best true accurate dyno versus non load bearing which cannot actually work under actual driving load as the Mustang does. Its all in the operator also and the correction factors and the tune also etc....and is best as a tuning tool. And a good shop that has a dyno jet would compare their output with a mustang but many would rather inflate egos also though...........
SO its a crap shoot and best used for tuning.... and if you want bragging rights its a spendy way to get it.... but generally a dynojet can inherently be as much as 15% off or just a few HP or damn near the same its in how they are set up..... Hers my old first cammed 13 with CAI scoop , SP headers HFC, and the old TSP 235/235 cam when it had .639/.623 lift.... My tuners very well respected, been in SEMA, two electrical engineering degrees and well smokes the competition. He's lucky his dyno is Mustang, he uses SAE as that's the correction factor your supposed to use not standard STD which is higher HP output numbers ...wrong not the standard.... and he does not smooth the graph as it shows where problem areas are, remember the deal is you going with split second capturing of a engines performance at a given speed under load ..while being tuned with HP tuning and in Tommy Wongs case also the stock hardware/software from GM... I literally had to wait once while he tuned a supercharged vette to gain 150 more HP than the stock crap handheld tune the guy got from the mechanic that installed it....Yes its a waiting list, yes he is worth the $550 to tune..... and he does not inflate numbers he has a remote weather station on the roof etc...... And its worth it know your not pulling timing anywhere, your AFR is good and your crap is tuned up and down run over and over.....And the tuner has a library of past tunes in the mega numbers knowing what to tweak and where and putting in a generic tune for your car before even running it from similar cars with similar mods for a starting point.... SO you basically get what you get with dynos and with mechanics etc..... Mine I am proud of and happy when I know my stuff is covered though it can be a case of a guy being so popular its too busy to be left alone long enough.....Tom Wong good guy..LOL And his favorite saying' Don't believe everything you read on the internet". IMO a good dyno sheet is unsmoothed, SAE corrected with out a absurd STD factor or lack of weather station;( factor just from a newspaper a week old weather report and a thermometer on the wall),( if they have one)....and includes the AFR ratio and done best on a load bearing dyno....... and cars are best tuned with the right software by a well experienced tuner Good Luck. Heart breaker versus Smarts faker.... what matters is going point A to B. https://www.facebook.com/Wongs-Perfo...-115667950915/
03-18-2018, 10:18 AM | #11 | |
03-18-2018, 08:40 PM | #12 |
Drives: 2012 V6 Camaro 2010 Camaro SS Join Date: Jun 2010
All the Mustang Dyno’s I have seen are not accurate and generally will calculate your horsepower and torque 15-20% less than what it actually is. If you want accurate numbers or dyno tune use a DynoJet dyno.
Mr. Clean
03-19-2018, 07:30 AM | #13 | |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
If what you're saying is true, my bolt on, small cam ls3 makes 577whp on a dynojet??! No. It's more likely that the Mustang Dyno that I was tuned on, is setup in a configuration to read higher than others. If someone wants to know if they make more HP than their buddy, go to the same dyno, on the same day.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
03-20-2018, 09:15 AM | #14 |
Drives: 2011 2SS/RS Convertible Join Date: Jan 2017
It doesn't matter if you use a Dynojet or a Mustang dyno. Yes, Mustang dyno's generally read lower than a Dynojet however dyno's are simply tuning tools, who cares about the peak numbers unless you're a lame bench racer??? The only thing that is important is that you use the same dyno for all stock or baseline pulls as well as post modification pulls, that way you can see your true gains. Keeping with the same dyno will show you an accurate percentage gain regardless of if you are on a DybnoJet or Mustang and at the end of the day you want to see what overall percentage of gains you have achieved with a modification. Jumping around to different dynos will just confuse you and at the end of the day you will not have learned anything worthwhile.
Richard Partlow
