Old 03-23-2018, 01:51 AM   #1
rtist
Drives: 2012 Camaro Lt
Unhappy (VIDEO) Hand / Parking / E Brake Not working
As you can see from the video below. There is no tension on the Ebrake whatsoever. At first I thought the issue might be a simple fix. So i adjusted the Ebrake by removing the Rotors and adjusting the spring tension there. But no luck.
https://youtu.be/FAe2tQ8qdhc
Any ideas??
Any help would be appreciated. Thank You!
Upload all your photos for free at
www.fb.pics .
For Free : No Charge : No Subscriptions
rtist is offline   Reply With Quote
Old 03-24-2018, 10:49 AM   #2
1Coopgt
1Coopgt's Avatar
Drives: All Black 2012 1LS
Did you check the e-brake cable at both ends from the handle to your rear brakes. Is it attached to every thing. Did the cable snap some where down there.
Mods, K&N CAI ,VTC , GM Perf Axleback Exhaust, Elite Eng CC and CSS, GM Strut Tower Brace,Carbon Fiber Anvil Spoiler,ASC T5 Splitter,Gen5diy Foglight kit.
1Coopgt is offline   Reply With Quote
Old 03-24-2018, 09:58 PM   #3
rtist
I believe it might have snapped. However, I haven't checked them as I've heard I need to remove the exhaust, heatsink and that it'll be near the drive shaft. Would you happen to know if that's true?
www.fb.pics .
Old 03-26-2018, 02:41 PM   #4
1Coopgt
1Coopgt's Avatar
To be honest I don't know . You had the E-BRAKE handle unbolted from the tunnel so you could have at least check at the handle end and tried pulling the cable up through the floor if it was attached to the handle.
brake, camaro, emergency, hand, parking
