04-13-2018, 12:43 PM | #1 |
Drives: Yellow 2014 2SS Convertible Join Date: Oct 2016
Is there any trick to getting an ODBII reader to connect to a Camaro?
I have a 2014 Camaro 2SS, and I believe an error code is preventing me from putting my convertible top down. So I purchased a Foxwell NT201 off of Ebay. I've never used one of these before, but figured I should be able to figure it out.
When the unit arrived I tried to connect it to my car, but it just kept cycling through the communication protocols and finally told me that my car is not responding. I tried the following to get it to work:
My assumption was that I got a bad unit, but then I tried plugging it into my partner's 2008 Chrysler 300 with the key off, then turned the key to on, and the thing connected up without a hitch. So there went that theory. Is there anything special I need to do to get a Camaro communicating with an ODBII reader? Is the reader I'm using the wrong one (it listed support for Camaros but they could be mistaken)? Any suggestions on what to try next? Thanks! |
04-13-2018, 01:04 PM | #2 |
Drives: Summit White 2014 2SS/RS 6spd Join Date: Mar 2016
Interesting, should just plug in and turn key... I never had an issue... make sure it is plugged in all the way, those connections are tight on mine. Good Luck!
Your car must be very fast! You were haulin' ass when I passed you!
04-13-2018, 01:14 PM | #3 |
Instagram: Sangstah
I'm thinking you got a bad unit, you should just be able to plug in and go.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
04-13-2018, 01:19 PM | #4 |
Guest
While I know this is not what you want to hear....
honest next step go to parts store (o'rielly, autozone, etc) and have them read you to code, or go to amazon.com and spend $12.95 on: https://www.amazon.com/Vgate-Bluetoo...h+obd2+adapter this is the vgate obdII reader that I use with my 2014 camaro. it pairs to the Torgue app which is completely free and has worked on everything I have tried it on. good luck |
04-13-2018, 04:59 PM | #5 |
Well, I think I figured this out. The instructions that came with my unit said that it must be plugged in and receiving power to work, implying that there was no battery. So I had it plugged into the USB port in my car when trying to connect.
Today I realized that it turned on without being plugged in, so I tried connecting to the OBD2 port without connecting the USB cable, and it worked. So if anyone else runs into the same problem...there's your solution. Unfortunately, it showed no codes. And even after clearing all codes my convertible top will still not go down. Not really sure what to do next... :( |
04-13-2018, 05:05 PM | #6 |
Do you have to have the "safety" net pulled out to open the top??? my 2011 has a net of sorts that has to be opened to get the top to come down...
2011 2SS/RS Convertible, Victory Red, Roto-Fab CAI, Stainless Power 1 7/8 headers, No Cats, Straight piped, Bo White TB, ZL1 CONVERSION, CDC Roll bar and some powder coating and dipping.
04-13-2018, 05:14 PM | #7 | |
04-13-2018, 07:20 PM | #8 |
No, you shouldn't have to do anything special.
I have 2 ELM27 BT scanners from different manufacturers that work without issue. Have you visually inspected the OBD port?
04-13-2018, 08:52 PM | #9 | |
Captain Gingerbeard
Drives: 2012 IOM RS/SS 6MT Join Date: Feb 2013
Generic code readers like that won't always pull manufacturer-specific chassis codes. So that's probably your issue.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads. Quote:
