04-24-2018, 06:30 AM | #1 |
Drives: 2018 Camaro 2SS Join Date: Mar 2018
Small Issue at the Gas Pump
Apologies if this has been covered, I did search before posting, but maybe I searched with the wrong terms. When I go to fill this car ('18 2SS) at my local filling station, using the capless setup as directed in the manual, the sensor in the nozzle seems to shut off well before the tank is actually full. If it's obvious that it's not there yet, I'll start it back up, of course, but as it gets closer, I don't want to do that. Any tips on how to make sure you get a full tank of gas?
Or am I the only one with the issue? 36 years of driving, and I can't pump gas.. |
04-24-2018, 06:42 AM | #2 |
Drives: '17- 1ag37 V6 traded, for 1SS 2018! Join Date: Mar 2018
Huh.
BTW, welcome! I have so far (3 weeks since purchase) haven't had the same issue. Every time it pops off, the gauge is right on the full mark. As I fill it, I can hear a slight change as if the tank is close to being full up. Would it be the nozzle? Change gas stations/pumps? |
04-24-2018, 07:20 AM | #3 |
Drives: 2017 Camaro Join Date: Mar 2018
There needs to be some empty space in the tank and filler for the EVAP system to work properly. When it kicks off, stop filling the tank. Do not keep topping it off. I'm pretty sure the manual tells you this also.
04-24-2018, 07:27 AM | #4 |
Retired from Car mfrs....
Drives: 2LT RS/HR-V Join Date: May 2013
Turn the pump upside down.....or....find a new station....not all pumps have the same trigger/stop
04-24-2018, 07:45 AM | #5 | |
I believe I've had the phenomenon happen at 2 different stations, nearby..my first thought was that it might be a defective sensor at that particular pump...but seems unlikely when it keeps happening at different places. |
04-24-2018, 07:48 AM | #6 |
Drives: 50th SS Convertible Join Date: Jul 2017
I have had similar issues at two different stations. It's not that it goes off early, just before its full, it goes off almost as soon as I start pumping when on empty. I just keep at it and I don't do a complete fill up.
04-24-2018, 08:14 AM | #7 |
Drives: 2018 1SS 1LE, 2015 RAM Ecodiesel Join Date: Oct 2017
Shove it in there all the way!
04-24-2018, 08:58 AM | #8 |
04-24-2018, 09:03 AM | #9 | |
Drives: 20 1LE 2SS M6 Rally Green Join Date: Mar 2014
One time I pushed it so I could get to the station near my house and ended up getting 19 gallons into it. Pretty amazing since it's rates capacity is 19 gallons so I took a picture. I couldn't have gone any further
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.” Ronald Reagan - |
04-24-2018, 09:13 AM | #10 |
603 Camaros
Drives: 2017 NGM I4 1LT Coupe Join Date: May 2012
There's a few gas stations in my area where this happens jronically my old neighbor worked for a gas pump service company and i asked him about it he said someone used parts from pre-2008 on the pump to repair the nozzle. They aren't supposed to anymore but it's not illelgal and cheaper then ordering the part new. He said it's fairly common at franchise stations outside of small corporations like shell and conoco and exxonmobil 100% branded stations. Then again this is the same guy who put gasoline into his diesel tractor this winter...
MY 2017 I4 CAMARO BUILD JOURNAL | YOUTUBE | INSTAGRAM | 316RWHP - 385 RWTQ HPTUNERS DYNO TUNE | 12.693s @ 105MPH 1/4 Mile |
04-24-2018, 09:13 AM | #11 | |
Drives: S O L D Join Date: Aug 2016
From the GM Website: Fuel Tank Capacity 72 litres / 19 gallons
Club F1FTY
2017 2SS 50th Anniversary Convertible Borla S-Type exhaust NPP| GM CAI | Color matched GM side skirts | Color matched 3rd brake light | Big Worm Graphics smoked out tail lights & rear reflectors | Oracle ghosted side markers | LED License plate bulbs | Door striker covers | Jam handle | Engine emblems from RiverCity Creations | 50th Center Console | Black bow ties | Hawk Performance ceramic brake pads | ZL1 Start button | CQuartz ceramic paint finish | Novistretch bra | S O L D |
04-24-2018, 09:18 AM | #12 |
Drives: Tesla M3 LR-AWD [Former 1SS owner] Join Date: Jan 2018
i've had this happen in different cars. I think it's the station pump more than the car. Some are senstive and you have to play around with the nozzle position to get a steady uninterrupted stream.
I haven't had it happen on the Camaro yet. I also let my gas go all the way down before refilling which helps if this ever does occur. |
04-24-2018, 09:49 AM | #13 | ||
Drives: 2016 2SS, Summit White, A8, NPP Join Date: Apr 2013
04-24-2018, 10:13 AM | #14 |
Drives: '20 ZL1 M6 Join Date: Apr 2017
Perhaps use the slower setting on the handle?
Mal
Ft. Lauderdale, FL '20 Camaro ZL1 M6 '22 Kawasaki ZX-14R |
