04-26-2018, 09:51 PM | #1 |
Drives: 2012 SS/RS MN6 Join Date: Mar 2016
Exhaust for single turbo
My single turbo kit is almost done and I'm wanting to know what you guys are running for exhaust. I have the option to either have it come out the front bumper or routed with a downpipe out the back.
Didn't want to cut into my bumper so I went with the downpipe. I currently have a Stainless Works retro chamber exhaust. I wasn't sure if the chambered mufflers were going to be restrictive with the turbo or not. I consider just removing them and replacing with a 3-inch pipe or continue to try to sell the system and have an exhaust made once the turbo install is complete. I was just kind of curious what everyone is running with a single turbo. |
04-26-2018, 09:54 PM | #2 |
The Retro Chambered catback from Stainless Works is a straight through style muffler. I wouldn't worry about it being a point of restriction. It's 3" as well.
04-26-2018, 10:08 PM | #3 | |
Just me over thinking crap as always lol |
04-27-2018, 06:51 AM | #4 |
Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
5 inch downpipe out the front fender.
04-27-2018, 08:36 AM | #5 |
Drives: 2014 SS 1LE Join Date: Apr 2014
Get rid of that stainless works catback. All the turbo guys i know running it either pull it off or cut the mufflers off because it is so restrictive. The piping might 3 inches, but the baffling is barely 2 inches and there are 2 sets of them. 3in straight pipe would be your best bet in my opinion. If you have no sound restrictions then either do cutouts or just dump under the car. I tried dumps under the car on my twin turbos and it sounded terrible and gave me a headache. Went to 3 in no mufflers.
04-27-2018, 08:44 AM | #6 | |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
i stole this picture from another thread in the bolt-on section
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
04-27-2018, 09:27 AM | #7 |
Drives: 2011 camaro ss convertible Join Date: Oct 2015
I dont know anything about turbos but I just wanted to add that I’ve actually cut in to the muffler of the chambered catback and there’s basically another piece of piping inside of it which is smaller, probably about 2.5 and then it has those wierd looking things inside.
04-27-2018, 12:23 PM | #8 |
04-27-2018, 12:25 PM | #9 |
I just did a quick look on the way out of the garage. I'll get a good look once I get home from work.
04-27-2018, 12:57 PM | #10 | |
edit: checked out the picture a little more and i would say the internal diameter of the muffler in the picture is 2.5"+. the baffles/dimples cause you to focus on the very end of the muffler which threw me off 3" all the way from the turbo to the tip would be better but i doubt the mufflers will kill much whp
2010 2SS/RS
04-27-2018, 01:55 PM | #11 | ||
04-27-2018, 03:33 PM | #12 |
Drives: 2013 Camaro SS Turbo Join Date: Apr 2014
the most important part of the exhaust system on a turbo car is the down pipe
also how much power do you want to make big difference on exhaust flow for 900 compared to 600
04-27-2018, 03:59 PM | #13 |
Drives: 2010 Camaro (M6) 1000+ HP SBE Join Date: Jun 2011
Dang, looks like the Sarlacc man eating worm on Tatooine that ate Boba Fett. A very miniature version that is
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam Brodix BP BR 3 Heads Kooks LT Headers and full 3" exhaust Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears McLeod RXT Twin HD Clutch & Upgraded Slave RPM Level VII TR6060 BMR Drag Suspension Package w/Strange shocks Carlyle 15" and M/T ET Street R radials 10.1 @ 143 mph 1/4 mile Last edited by BiggFoot; 04-27-2018 at 04:14 PM. |
04-28-2018, 12:31 PM | #14 |
