07-18-2018, 07:46 PM | #1 |
Train Driver
Drives: 2018 Summit White ZL1 1LE Join Date: Jun 2013
Weapon-X Stage 1 no tune
Has anybody installed and have a before and after with the Wrapon-X no tune intake.
I am trying to decide between the Weapon-X carbon intake, Rotofab, or K&N carbon one. Still not convinced any will make more power, but Id like more blower sound, and the look of the open air intake. All three claim 20+ whp increases.
2018 Camaro ZL1LE
/ / Katech TB // RotoFab Dry // Borla 60606 // ATI Super Damper / / |
07-18-2018, 07:48 PM | #2 |
Drives: 2017 ZL1 A10 Summit White Join Date: Apr 2018
+1 also interested.
07-18-2018, 08:10 PM | #3 |
Drives: Grandad's C2 L89 Join Date: May 2017
I'm seriously considering the WX stage 1 CAI myself.
Member Intimidator posted some pics here.https://www.camaro6.com/forums/showt...=518262&page=5 His pics are on post #70.
2018 ZL1 1LE sw/PDR
07-19-2018, 04:18 AM | #4 |
Drives: 69 GTO, 05 GTO, 2018 Silver ZL1 Join Date: Jan 2012
I didn't dyno anything because it was impossible to find shops around here. Plus I was debating on doing just bolt ons to keep the warranty...I also did alot of porting and added a ported TB at the same time.
Once I Visited Weapon-X, I knew they were going to be doing my build, dynoing, and tuning. The open CAI does give you more SC sound...I went this route because it worked well with my other mods and stage 2 will look the same. |
07-19-2018, 05:08 AM | #5 |
Drives: 2018 ZL1 A10/2018 GT350R #JR603 Join Date: Jan 2017
I’m not a fan of weapon x filter. Seem small and out of place. I own the Roto-Fab w/ Blue Dry Filter. Have seen the K&N in person & it is sexy!!! I noticed a performance improvement with the Roto-Fab. Even improved the MPG
2018GT350R+2018 ZL1 "Red Hot" A10 w/ PDR, Nav, Carbon Fiber Hood insert, Carbon Fiber Dash Insert, Carbon Fiber Fuel Dior & Sun Roof. T/M T-Body, Roto Fab & Borla S Type.
07-19-2018, 06:33 AM | #6 | |
Train Driver
2018 Camaro ZL1LE
07-19-2018, 07:02 AM | #7 |
American Gearhead!!
Drives: ZL1 1LE/GT350/Ford RS/Gen 2 Raptor Join Date: Mar 2013
I would also recommend the rotofab and stay clear of weapon X. Rotofab has been around for years and has a proven CAI system. I had a rotofab on my Gen 5 ZL1. I decided to try something new as I also liked the CF of the WX system, but returned it as it was damaged upon arrival (Since the box was perfect, I believe it was damaged when shipped). They made me take pictures and after several back and forth emails I returned it and got a refund(minus $10). I never even followed up on why I was shorted on the return since it was already so frustrating. Not a good first impression, I won't buy from them again.
07-19-2018, 03:26 PM | #8 | |
There are enough posts on here from reliable sources that unless you are tuning, a CAI is pretty much for sound and looks, and if lucky you may pick up a couple ponies. So chose the intake that fits the way you want your engine bay to look. I did prepare for the next stage of the build by opening up the driver side front grille area, so more air can feed into the front opening of the Weapon-X box. Alot of rubber and plastic can be cut away...no issues with water, as this is my DD. |
07-19-2018, 03:58 PM | #9 | |
Train Driver
If the power claims are BS, then it's a shame all companies keep claiming the gains in power. If you under report air flow, timing will increase and the air fuel will lean out at WOT, until the fuel trims go positive which will eventually add back more fuel in WOT operation, but timing will stay slightly advanced due to a little less load being calculated due to decreased lb/min conversion from the MAF under reporting.
2018 Camaro ZL1LE
07-21-2018, 05:48 AM | #10 |
Drives: 2017 ZL1 Join Date: Apr 2017
Why i dont use anything but a stock filter. Those filters ingest dirt.
2017 ZL1 Hyper Blue Metallic M6
1996 Z28 Polo Green F1-D Procharged 383- 490rwhp |
