07-19-2018, 02:33 PM | #1 |
Drives: 2010 LS Join Date: Jul 2018
wheel question camaro
I own a 2010 LS and was wanting to upgrade the wheels and tires from 18” to 20”. I found a nice set off a 2016 RS 20 inch but not sure if they would fit my car? any help or advice would be appreciated.
07-19-2018, 02:37 PM | #2 |
Drives: 2012 Camaro RS 2LT 6spd man Join Date: Aug 2013
I think the offset might be off, but the wheel lug pattern should be the same.
07-19-2018, 02:41 PM | #3 |
is the offset a big issue? not sure exactly what that means. thanks
07-19-2018, 02:49 PM | #4 | |
376 cubic inches of fun
The wiki page on this forum will tell you what the correct offset and wheel widths for the Gen5, and a little google work will lead you to several resources for measuring offset and calculating the correct offset for non- OEM wheel widths. |
07-19-2018, 03:27 PM | #5 |
wiki says my stock wheels are 18x 7.5 w a +38mm offset. can’t find what 2016 would be at 20 inch.
07-19-2018, 03:42 PM | #6 | |
https://www.camaro5.com/forums/showthread.php?t=446314 |
07-19-2018, 04:43 PM | #7 |
Drives: 2001 Chevrolet Camaro Join Date: Feb 2018
You can also use websites like willtheyfit and wheel-size as a reference.
07-19-2018, 04:44 PM | #8 | |
https://www.camaro6.com/forums/showthread.php?t=503305 |
