Old 07-24-2018, 10:47 AM   #1
Adoyle92
Adoyle92's Avatar
Drives: 2010 Camaro SS
Car Battery/Alternator problem
I was driving my 2010 this morning and noticed my battery voltage was down to 12.5 it normally is around 14.5-14.7. After about 5-10 minutes of driving the voltage went up to 14.3. When I got to where I needed to be I turned off my car and turned it back on about a hour later to head home and battery voltage was 14.3. Then as I drove home in about 5 minutes it dropped all the way to 12.7 and stayed there until I got home. Is this my alternator about to die or is battery just not holding a charge?
Adoyle92 is offline   Reply With Quote
Old 07-24-2018, 10:57 AM   #2
qcman
qcman's Avatar
Drives: 2013 Camaro 2SS RDP Tuned L99
I don't think its either. The car can regulate voltage charging depending on the battery's state of charge. It will charge less when the battery is up and more when it's a little down. And that is normal.
My car can vary depending on the amount of use the car gets. I think you are fine but perhaps someone else will comment as well.
qcman is offline   Reply With Quote
Old 07-24-2018, 10:58 AM   #3
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
original battery? if so replace ASAP with a good AGM style....also chase your grounds....take care of the basics before opening a can of worms....saves time and $$$...good luck!
peace
Old 07-24-2018, 11:03 AM   #4
Adoyle92
Adoyle92's Avatar
Not original battery, battery was replaced 2 years ago this October
Old 07-24-2018, 11:55 AM   #5
blake-b
blake-b's Avatar
Drives: 2009 ZR1
That is normal behavior.
Old 07-24-2018, 12:43 PM   #6
SSEssence
Instagram: Sangstah
SSEssence's Avatar
Drives: 2019 Camaro 1LE
That is normal, I saw that too and wondered but its normal behavior
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717
SSEssence is offline   Reply With Quote
Old 07-25-2018, 08:43 AM   #7
Mike.Ss
Mike.Ss's Avatar
Drives: 2014 2SS/RS Bright Yellow
Normal.
One of my earlier posts pointed to another post that describes this behavior.
Sent from my SM-G950U using Tapatalk
Mods: NEC5 window stickers (+10hp)
Mike.Ss is offline   Reply With Quote
Old 07-25-2018, 09:55 AM   #8
gutterball
gutterball's Avatar
Drives: 2014 1LS M6 Supercharged
Send a message via AIM to gutterball
This is normal operation, when the system sees your Batt is charged, it shuts off, when this happens your just reading your Batt. Voltage. If your Batt starts to get low, alternater kicks in, now your reading your Alternater Voltage.
gutterball is offline   Reply With Quote
Old 07-25-2018, 10:12 AM   #9
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
The voltage you see on the gauge is the charging voltage and it varies as required to keep the battery charged but not overcharged.
When the charging voltage stays high all the time, your battery is getting old. 2 years is not old, unless you're abusing it, like for example storing the car for the winter without a battery tender.
Rock-It Man is offline   Reply With Quote
alternator, battery, help me please
