![]() Drives: 45th anniversary camaro ss Join Date: Sep 2014
MRR228
I have the MRR228 on my 2012 LS3. The offset on the front is 23mm on 10" wheels. They stick out beyond the fenders by about an inch or more. I`m wanting to know if it`s best to do a 10" at 35mm offset, or 9" at 23 or 35mm.
![]() ![]() ![]() ![]() Drives: 2010 CAMARO SS Join Date: Apr 2010
this is what i have and is perfect
size is 20x10 35mm offset 275/40/20 i have a brand new mrr228 gloss black,mounted new tire as well if you are interested |
![]() ![]() Drives: camaro Join Date: Nov 2011
20x10 23et will not sit out of the fender line/ example your same body car in a ZL1 model uses exactly those specs / if you previously had other wheels and ran a spacer just make sure who ever installed the M228 removed the spacers as well.
a inch is 25.4mm meaning if your 100% correct in your calculations the wheel would need to be a 48 off set which is totally off. we offer 20x10 23et and also a 35et for a conservative fit 23et is if you want the ZL1 look or stance you should have a 275 ser tire and it should not stick out. Last edited by Carlos_MRRWheelsInc; 09-12-2018 at 06:09 PM. |
The rear tires are 315`s on 20x11 and fit fine. The fronts are 275`s on 20x10 with a 23mm offset and are beyond the fenders.
![]() ![]() Drives: 2015 Z/22 Join Date: Aug 2015
Pics?
What are your camber specs? Do you know for sure that the front wheels are 20x10 +23mm (I read some threads in the past like this one and it turned out that the front wheel wasn't what the owner expected)? ![]()
#6 |
post pictures buddy. but I will say we only make 20x10 23et which will never ever go out the fender, we also make a 20x10 35et which it will also not go out the fender and also 20x9 will not go pass the fenders....
post some pictures buddy, possible camber/ maybe spacer still on car/ something. we are all just trying to help. if you look around any post on M228 we have hundreds of customer with those specs on and not one problem like that your describing. another possibility is that you may not even have M228 wheels... any way add some pics lets check this issue out. |
