09-23-2018, 07:00 PM | #1 |
Drives: '18 Camaro SS Join Date: Sep 2018
Procharger with Stock manifold
So I have decided to say bye to the factory warranty and go ahead and start building my car I am torn between the P1x and D1x Prochargers. I am thinking to keep the build super simple (for now haha). D1x Procharger stage 2 kit w/ Race bov on 10lbs, Lt4 fuel setup, tune and MT ET Streets. Hoping for 650whp.
I really want to keep the car super quiet and as much as a sleeper as possible. Would it be a terrible idea to keep the factory headers/exhaust? I realize I will lose power. Would 650whp on 10lbs be feasible for this build? |
09-23-2018, 07:53 PM | #2 |
Drives: 2017 Camaro 2SS Nightfall Gray vert Join Date: Jan 2018
Congrats on your build...welcome to the dark side.
I haven't had my Procharger for a few years, so will let the experts respond. Looking forward to watching your progress. I seem to recall Pray had a car setup with the P1x running 650whp. Off the top of my head it seems like most of the cars run headers over 600whp. I do know that Laynlo ran his completely stock motor up over 700whp with the manifolds, but he also had alky injection going.
2017 Camaro 2SS vert - Nightfall Gray
Magnuson Heartbeat SC - Tuned by JRE Racing 776whp/745wtq (12psi) 2018 Corvette Z06 vert- Black To be tuned by JRE Racing TBD performance |
09-23-2018, 08:25 PM | #3 |
Drives: 2018 ZL1 Join Date: Oct 2011
That plan should get you where you want to be. No it’s not a terrible idea since these factory exhaust do flow pretty well, however like you already know you will sacrifice some power. I also still run factory exhaust.
2018 ZL1…Many mods to come
09-23-2018, 09:06 PM | #4 | |
09-23-2018, 09:08 PM | #5 |
Nice! Good to know that other people have also done this. Did you go with the Helical gears on your procharger?
09-23-2018, 09:25 PM | #6 | |
Drives: 2016 1SS NFG A8 Join Date: Aug 2017
2016 NFG 1SS A8
Options-2SS Leather/NPP Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA |
09-24-2018, 07:02 AM | #7 |
Drives: 2017 50th Anniversary 2SS Join Date: Sep 2016
I wanted to keep mine quiet as well but let me tell you about that Race bypass!. It's LOUD!. dead giveaway.
Also I ran into the stock Cats being a bottleneck & contributing to some knock so I replaced the stock manifolds with catless ARH LT's and wow what a difference. I would say as long as you maybe get some Cat delete pipes at the minimum you'd be fine at that power level.
Former Ride: 17 Camaro 2SS, M6 - Fifty | Procharger P1SC | 3.7 Pulley | Stage 2 IC | Race Bypass | DSX FF Kit | JRE Custom E85 Flex Fuel Tune | LT4 Fuel System | JMS Voltage Booster | MSD Plug Wires | American Racing 1-7/8's LT Headers Full System Catback | Baro Breakout Harness | LT4 Map Sensor | Katech Ported TB | MMS Oil Catch Can | 160 Thermo | Solo Performance J-Pipes
09-24-2018, 08:16 AM | #8 | |
Also, 2 questions - Has the catch can helped with the oil issue? Why did you go with 1 7/8 and not 2" LTH? |
09-24-2018, 08:59 AM | #9 | |
The other alternative is just go with stock procharger bypass valve. That one is quiet but just be absolutely sure about it. Research it, etc because many have regretted they didn't go with the race bypass. So regarding the KR I was getting. I have a smaller 3.7 pulley on my P1 so my boost was almost 11lbs at redline. Not sure how efficient the P1 is at that boost level but I bet if you went with the D1 you'd be starting off on the right foot. I believe the way it works is the additional boost creates more heat and so my timing had to be dialed back quite a bit to resolve a few degrees of knock at the top. My tuner said if I eliminate the cats it will drop the boost down a bit but the LT's would more than make up for that with better timing and better efficiency in getting the air in and out of the motor. They really woke up the top end very noticeably. I went with the 1 7/8's because I wanted 600-650 and felt the 2in were just overkill for my power level and also didn't want to run into any chance of rubbing the steering column. I also wanted to retain a little low end torque. If my goal was 800+, there would be no doubt that 2in is the way to go. The Oil catch can is a must once you see the amount it catches and be sure to either go with a metco valve cover breather or a vented catch can so you don't blow out the front lower crank seal.
09-24-2018, 10:24 AM | #10 | |
Drives: 16’ 2SS A8 HBM Procharged Join Date: Jun 2017
Not sure what your goals are, but I went beyond my expectations with this setup and just ran a 10.6@130.9 the other night and was super happy with it. An amazing daily driver too. Because of when the power comes on, I averaged 27mpg on the way home from the dyno, and have no problems letting my wife take the car and go to work with it. If I had to do it all over again, I wouldn’t change anything EXCEPT maybe upgrade to a better head unit because I didn’t realize how much money it is to do it after the fact. Just poor research on my part.
16' 2SS A8 Hyperblue | P1SC-1, Race IC | JMS fuel pump voltage booster | Jannetty custom tune | Elite E2-X catch can | M017 Wheels
09-24-2018, 11:05 AM | #11 | |
09-24-2018, 11:07 AM | #12 | |
09-24-2018, 11:23 AM | #13 | |
Currently using pilot sport 4s 305/30/20 and they hook up okay in warm weather. Obviously at this power level no matter what you’re going to spin some. At the track I use 17” ET street R and dead hook off the line. I know guys running 20” ET street SS as daily tires and they like them a lot.
09-24-2018, 08:00 PM | #14 |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
I have a 2017 SS 1LE with a D1SC with the stage 2 intercooler and a Tial 2" surge valve. I started out with the stand PC Pro-Flo valve and regretted not putting the 2" valve on it from the get go.
The larger valve is more efficient, it responds faster and allows boost to come on faster. Yes it is louder, but being loud as the only negative it is well worth it. I have ARH catless headers on my car, with a Alky Controls meth injection system and a very conservative tune I put down 650rwhp at 10.5lbs of boost. I contemplated the D1X but Procharger was adamant I would give up a decent amount of power down low and would only gain it way up high along with being able to put me over my HP goal that I was trying to stay with in.
2019 Corvette Z06 2LZ A8 - Halltech CAI, AWE non-catted X-pipe, Mamo V2 ported TB 592rwhp, bone stock 566rwhp
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD |
