11-03-2018, 12:02 PM | #1 |
Drives: 2014 Camaro 2SS/RS/1LE Join Date: Oct 2013
Brey-Krause Harness Bar Install and Sparco Harnesses
I'm installing a Brey-Krause harness bar and the Sparco Harnesses. My questions is where do you anchor the inside piece of the harness too. The outside one clearly connects to the down rod on the harness bar, but nothing for the inside harness to connect too.
Any help or suggestion is appreciated.
Crystal Red Tintcoat, NPP, Recaro Seats, Sunroof and SLP Skip Shift, ZL1 rockers, TSP Stage 4 "F35" cam, PRC 260cc heads, GPI radically ported LS3 Intake, K&N CAI and JDP Motorsports Stage 2 Clutch Reservoir Kit, TSP Longtubes, off road connectors and high flow cats, aFe POWER Solid Subframe mounts, Brembo 6 piston calipers and two piece rotors
11-03-2018, 09:00 PM | #2 |
Show me a pic.
11-29-2018, 04:31 PM | #3 |
Drives: 2013 2SS 1LE NPP GBE Join Date: Sep 2012
You've seen mine, right?
11-30-2018, 09:50 AM | #4 |
Drives: 2010 2SS/RS Join Date: Dec 2009
you either have to buy a Tank Plate of use the BK side mount which sells for about 50-60 bucks for both seats. Its stainless steel really nice piece. Here is the link.
https://www.bkauto.com/R_9150_Inside...o_p/r-9150.htm
Orange Krush II
