11-20-2018, 11:18 PM | #1 |
Drives: SC 2012 V6 Join Date: May 2016
Valve float
Has anyone ever experienced valve float in these motors? I have been boosted for the last 40,000miles and currently at 16psi of boost for the past 3000miles, I started noticing in the higher rpm range, 6000-7000, it would want to break up some in sound and power which it has never done on this setup before. The car has seen many track passes as well. Running ZL1 pump and alky meth so not sure if it is running out of fuel or not.
Supercharged V6 - 11.756 @ 122.75MPH
11-20-2018, 11:28 PM | #2 |
'It's an experiment'
Did you do cam with springs? If so, how many miles on them?
-Don
747 RWHP 794 RWTQ
11-20-2018, 11:42 PM | #3 |
No cams or springs done, motor is 100% stock and never been touched.
11-21-2018, 07:49 AM | #4 |
Drives: Fastest 2010 Camaro V6 Join Date: Apr 2010
Turbo guys were running 24 PSI on stock springs.
11-21-2018, 12:53 PM | #5 |
Drives: 2010 camaro limited edition turbo Join Date: Mar 2014
I am interested in what mods you did to run 16 PSI? You said you added Meth and Zl1 fuel pump but did you do anything else to get to that level of Boost? That seems like a lot for that much compression. I run 10-12 PSI but am apprehensive to move up. Who did your tune? Are you automatic or stick? I'm impressed. That thing must be lightning fast. Good for you! I know Magnum has really pushed the limits, unbelievable how these little engines perform!
11-21-2018, 03:55 PM | #6 | |
Catless downpipes 3in piping for intake Larger air filter Alky meth - 100% meth zl1 pump 3.91 gears 3800 stall converter Overkill tune Plans are to go dual nozzle meth and rebuild the supercharger with a new impeller this winter.
