Old 12-21-2018, 10:05 AM   #1
Nighthawk89
Nighthawk89's Avatar
Drives: 2011 Camaro 2Ss M6
Nick Williams 103 “boosted” TB?
Anyone else running this Throttle body?
Nighthawk89 is offline   Reply With Quote
Old 12-22-2018, 02:43 PM   #2
Stubbsy
Stubbsy's Avatar
Drives: 2012 2SS RS
Originally Posted by Nighthawk89 View Post
Is there such a product? Anyone else running this Throttle body?
I run a Nick Williams 102mm boosted throttle body on my Harrop supercharger.
Stubbsy is offline   Reply With Quote
Old 12-22-2018, 04:24 PM   #3
Nighthawk89
How do you like it? They make the 2650 version, correct?
Old 12-22-2018, 10:17 PM   #4
lionssfan
lionssfan's Avatar
Drives: 2010 2ss camaro
are these TB problem free after a tune of course .?
2012 zl1 stock 7000 miles
2010
TVS2300, BTR cam PD stage 3, ID1050 injectors, CHE bronze trunnions, 7.400" pushrods,.660" lift platinum springs, Titanium ret, Zl1 fuel pump, Kooks LT headers, High flow cats, Roto Fab CAI, Corsa exh., Mellings oil pump, HD chain, ls2 damper, all synthetic, BMR control arms, zl1 toe link, BMR cradle mounts, W/bottle relocation, air scoop deflector, Hennessy wheels, two piece rotor, morimoto fogs, DRL harness, coilovers, Heads up install, mgw shifter, slps splitter, slp spoiler, zl1 side skirts, painted strips, debadged, tinted, 2018 emblems.
Edit Signature
lionssfan is offline   Reply With Quote
Old 12-22-2018, 10:33 PM   #5
Pro-tuned
Angewendet Ingenieur
Pro-tuned's Avatar
Drives: 14 Camaro ZL1
Running NW on a Whipple and works great (if properly tuned).
LQ9, Iron Block, Forged internals, 408CI, Jannetty custom cam, TS short block, Whipple, Hardened Jackshaft, PRC 260, 2X3 Dynatech Full Competition, HF Cats, CAI, NW 103, Chee, ID 1300, COPO Breather, MSD, Fore Dual Pump, ultratorque, E85, dual Meth, True Trac, 3:45, 1500hp axle-shafts, DSS CF, BMR, custom Pearl/Candy paint by Jaidah.
Pro-tuned is offline   Reply With Quote
Old 12-22-2018, 10:50 PM   #6
Nighthawk89
As far as I’ve heard the newer “boosted” versions are successful in maintaining blade position if that’s what you are asking. Before they were difficult to tune and maintaining blade stability under boost.
Old 12-22-2018, 10:51 PM   #7
krisprz2010camaross
krisprz2010camaross's Avatar
Drives: 2010 Camaro 2ss/Rs Transformers
What’s the major difference between a regular Nick Willams 102mm throttle body and boosted 102mm throttle body? I have the regular one, but wondering if it’s worth it/needed to change out for the boosted version when I go forced induction
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage
LS3 conversion
Vararam intake(tune model)
Kooks LT headers & cats delete
Corsa ZL1 3" exhaust
RedBarn Racing Tune
CMS Stage 3 Cam
AFR CNC ported heads
MSD Spark plug wires
LNC-2000 Launch controller
NGK TR6 Spark Plugs
1le strut tower brace-TPIS spacers
Nick Williams 102mm throttle body
Fast lsxr 102 intake manifold
Slp 25% UDP
Katech Tensioner Pulley
Circle D 3600-3700 multi disk Stall
GM 3.91 gears
DDS carbon fiber driveshaft
ZL1 fuel pump & injectors
Flex fuel sensor(91/E85)
https://wheelwell.com/kris-perez
krisprz2010camaross is offline   Reply With Quote
Old 12-22-2018, 11:43 PM   #8
DSMer1
Drives: 14 and 15 SS's
Stronger motor and or better gears in the motor.
The regular version had a problem with slamming shut under boost
Bolt-ons!
DSMer1 is offline   Reply With Quote
Old 12-23-2018, 02:24 AM   #9
lionssfan
lionssfan's Avatar
I read that it also has better seals due to the higher boost pressure
2010
Edit Signature
Old 12-23-2018, 02:27 AM   #10
Stubbsy
Stubbsy's Avatar
Drives: 2012 2SS RS
I originally had a BBK 102 and it was going into limp mode on decel when the throttle auto blipped. The Nick Williams one has not had the same problem.
Old 12-23-2018, 03:11 AM   #11
krisprz2010camaross
Same thing happened to me. Had the BBK 102 throttle replaced and it did the same thing. No problem with the Nick Williams
LS3 conversion
RedBarn Racing Tune
CMS Stage 3 Cam
NGK TR6 Spark Plugs
Slp 25% UDP
GM 3.91 gears
Old 12-23-2018, 03:12 AM   #12
krisprz2010camaross
Worth the upgrade then?
LS3 conversion
RedBarn Racing Tune
CMS Stage 3 Cam
NGK TR6 Spark Plugs
Slp 25% UDP
GM 3.91 gears
Old 12-23-2018, 10:16 AM   #13
Nighthawk89
I would say so.. but maybe once your boosted? There is talk of even larger Nick Williams being produced and would be valuable under boost. I am going to be running nicks 103 boosted version however look forward to the release of an even larger setup. When attempting to max effort a top mount/twin screw the bigger the better!
Old 12-23-2018, 10:40 AM   #14
krisprz2010camaross
Probably, will add that to the mod list lol.
Nick Williams makes a good product for sure!
LS3 conversion
RedBarn Racing Tune
CMS Stage 3 Cam
NGK TR6 Spark Plugs
Slp 25% UDP
GM 3.91 gears
