12-29-2018, 09:05 AM | #1 |
Emerald Coast Camaros
Drives: 2017 50th Camaro LT2/RS Join Date: May 2011
Rear Reflector Lighting
So has any one considered adding LED strip lights to the rear reflector in the rear bumpers. I did this to my bag reflector on my HD and the lights come on as running lights any time its on. How would they be removed? I used a heat gun on the bike and purchased replacement reflectors and separated them and installed the lights and glued them back together and installed and wired them up. Would not be to hard...
2017 LT2/RS, 50th addition. Airaid CAI, Solo Performance Axle back, sunroof, Smoked Led Markers
12-30-2018, 01:14 AM | #2 |
Drives: 2017 2SS, 2023 3LT RS, 2011 2LT RS Join Date: Aug 2014
12-30-2018, 07:30 AM | #3 | |
thanks ordered a set, will post up pictures when I get them installed..
12-30-2018, 09:01 AM | #4 | |
Camaros Of Northwest Ohio
Bill
2023 2SS 1LE Red Hot
2016 2SS Black / Black & Arenaline Red (sold) 2023 GMC Canyon Denali 2013 2SS / RS - AGM / Jet Black (sold) 1970 1/2 Z/28 Classic Copper / Tan (sold many years ago) |
01-01-2019, 08:56 PM | #5 |
Drives: 2016 Camaro Rs Convertible Join Date: Dec 2018
Just a heads up they’re a pain to install.
01-02-2019, 11:51 PM | #6 |
Drives: 2016 M6 2.0T Join Date: Nov 2016
Please explain. Do you have to remove the entire rear valance? Break open the tail light housing?
RS Package, HD Cooling Package, Brembo 6 Piston Front Brakes, SRP Racing Pedals, Soler Performance Throttle Controller, Dyno Tuned by Trifecta, Velossa Tech Ram Air, Mishimoto Intake, aFe Air Filter, Mishimoto Charge Pipes, ZZP 67mm Throttle Body, Trifecta T40 Stage 2 Turbo, JacFab Recirculation Valve, PTP Turbo Blanket, ZZP Catted Downpipe, Mishimoto Pro Cat-Back Quad Tip Exhaust, Mishimoto Catch Cans, Mishimoto Coolant Reservoir Tank, GM SEMA Grill, Ikon Motorsports Front Fascia Extension, Ikon Motorsports 1LE Spoiler, American Authority ZL1 Side Skirts, AMPP Quad Tip Rear Valance
01-03-2019, 12:40 AM | #7 |
No. I just backed onto ramps removed the rear diffuser/valence screws and used a long screwdriver to push to diffuser out far enough to remove the screws holding the reflectors in(kinda hard to explain but it’s almost impossible to get to those screws). wiring is just tapping into the wiring harness running to the tailights. I’ll try to do a vid explaining a easier method I discover once I got to the right side for removing the reflectors.
01-03-2019, 07:45 AM | #8 | |
Drives: 2016 Camaro SS Join Date: Sep 2018
01-03-2019, 07:56 AM | #9 |
01-03-2019, 08:07 AM | #10 |
Ok thanks, so they are definitely not just red like the reflector. It is hard to tell what color they are by the link because there are 2 pics, one red and one white.
01-03-2019, 08:09 AM | #11 |
01-03-2019, 08:18 AM | #12 |
01-27-2019, 05:02 PM | #13 |
01-27-2019, 07:00 PM | #14 |
I’ve got a set just have not installed them might do it tomorrow
