Old 01-10-2019, 05:11 PM   #1
lionssfan
lionssfan's Avatar
Drives: 2010 2ss camaro
tvs2300 spacer plate what is it?
I've seen on several builds on this site mention spacer plate under the tvs2300. R%D has been mentioned. what exactly does it do and require in other parts that need to be upgraded if any? thanks
2012 zl1 stock 7000 miles
2010
TVS2300, BTR cam PD stage 3, ID1050 injectors, CHE bronze trunnions, 7.400" pushrods,.660" lift platinum springs, Titanium ret, Zl1 fuel pump, Kooks LT headers, High flow cats, Roto Fab CAI, Corsa exh., Mellings oil pump, HD chain, ls2 damper, all synthetic, BMR control arms, zl1 toe link, BMR cradle mounts, W/bottle relocation, air scoop deflector, Hennessy wheels, two piece rotor, morimoto fogs, DRL harness, coilovers, Heads up install, mgw shifter, slps splitter, slp spoiler, zl1 side skirts, painted strips, debadged, tinted, 2018 emblems.
Edit Signature
lionssfan is offline   Reply With Quote
Old 01-11-2019, 11:11 AM   #2
SannerRacing
SannerRacing's Avatar
Drives: 2010 1SS RS IOM
It's made out of phenolic material that is supposed to separate/isolated the blower from the plenum to reduce heat transfer. And it increases the plenum volume. It didn't make much of a difference that I saw other than the intake tube rubbed the hood.
Forged LS3 416ci, Maggie TVS2300 @ 13lbs boost, McCleod twin disc clutch, GForce 1320 nine-inch 389 gear ratio, Hurst line-lock, 750 whp 700 wtq
SannerRacing is offline   Reply With Quote
Old 01-12-2019, 01:46 AM   #3
Missile Man
Missile Man's Avatar
Drives: 2010 2SS/Black
I installed the phenolic spacer when I installed my super charger. I live in AZ and it keeps the SC cooler by isolating it from the engine. The kit came with everything needed to install including the FI spacers.
2010 Black 2SS L99
Mods:
* CAI Intake
* Magnuson MP2300 TVS Supercharger/RDS Spacer
* Vector Motorsports Tune
* Stainless Power LT/Hi Flow Cats/Tru X-* Pipe/36" J-Pipes/40 Series
* R1 Concepts ceramic pads and slotted/drilled rotors
Missile Man is offline   Reply With Quote
Old 01-12-2019, 03:21 AM   #4
lionssfan
lionssfan's Avatar
how much cooler if you know? added preformance great, but not as important.
2010
Edit Signature
Old 01-12-2019, 05:30 AM   #5
Missile Man
I haven't purchased a IR temperature gauge but during the summer (110 deg +) and with the air on only raised my engine temp by about 1 to 2 degrees. Not concerned about any HP gains, more for the heat insulator.
2010 Black 2SS L99
Mods:
* CAI Intake
