01-19-2019, 10:30 AM | #1 |
"1/LE Rebel Alliance"
Drives: 18 Black 1SS 1LE “Siouxsie Join Date: Nov 2013
Airbags Deploy on track
Anyone have this happen to them? I know it’s Jalopnik...which is like VICE. lol
https://jalopnik.com/curtain-airbags...ing-1831869262 |
01-19-2019, 10:34 AM | #2 |
Drives: '18 1SS 1LE Join Date: Sep 2017
GuitarmageddonZL1 airbag deploy video.
'18 1SS 1LE Black, PDR
01-19-2019, 01:47 PM | #3 |
It's happened to a couple of camaro6 members. It's ridiculous. Theres videos out there of other 6th gens, 5th gens, even a Cadillac doing this
01-19-2019, 03:18 PM | #4 |
I saw the Guitarmeggedon vid.
Isn’t this a very very slim chance of this happening though? |
01-19-2019, 05:25 PM | #5 |
Drives: 2019 ZL1 1LE Join Date: Feb 2017
The problem is that there doesn't seem to be a specific reason they go off. Guitarmaggedon's went off just from a loud exhaust, this guy's went because he was spinning when he hit a little dip in the pavement, two others have gone off when going over rumble strips on track, and I've also seen other Chevy vehicles having theirs go off just hitting a bad pot hole.
Old: 2017 SS 1LE
Old: 2017 ZL1 Current: 2019 ZL1 1LE |
01-19-2019, 05:53 PM | #6 |
I had a friend try to compare the airbags deploying with the engine issues the GT350 has, then sent that Jalopnik article as proof as a significant problem.
My reaction was “these aren’t even comparable” |
01-19-2019, 08:45 PM | #7 |
Drives: 2018 Hyper Blue 1SS 1LE Join Date: Jul 2011
I’ve seen it happen to a 5th gen. Few years ago when we were setting up the camarocross course at camarofest in BG. In a low speed turn popped the air bags. Not sure why they went off car didn’t slide or hit anything.
Ryan B.
Ryan
* 2018 1SS 1LE Camaro Hyper Blue Metallic Car Build: http://www.camaro6.com/forums/showth...0#post10049680 |
01-19-2019, 10:35 PM | #8 |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
I’m sorry, but that event at autox doesn’t surprise me much. Aggressive throttle+spin into sideways+ car dips up and down while impacting cones. The car is jostled decently.
Maybe a touch over sensitive cal, but not surprised given the event combo. |
01-20-2019, 01:27 AM | #9 |
Drives: 2018 Camaro SS 1LE Join Date: Jul 2018
Far too sensitive. Autocrosses are typically very dynamic for forces - an air bag deployment should not happen...makes me think a nano second about not tracking the car...
A good run will put a car in all sorts of odd situations...including slides (only hit cones!). |
01-20-2019, 07:45 AM | #10 |
Drives: 22 ZL1 1LE Join Date: Nov 2014
The airbags didn't deploy making a run to the grocery store. He spun out and at the same time & hit a pretty aggressive pothole (should be a lawsuit whoever hosting the event) People act as if the system has ages to calculate what happened. AB deployments are milliseconds and is either Y/N no in between. I think the system performed exactly how it was intended. I've literally went airbone in my 1LE and slammed my frame coming down getting a slight head injury (6'2) & my airbags didn't deploy.
01-20-2019, 08:40 AM | #11 |
You can see the crack/pothole between and just beyond two pointer cones.
Spin initiated around 60mph. Car goes into an aggresive (near 1.25g) backwards/sideways spin at 30mph+. Driver does not clutch in (RPM), holds firm brake (brake travel indicator) and does minor coutersteering while this slide is happening and when the car hits the crack/pothole... |
01-20-2019, 09:26 AM | #12 |
I wouldn't be happy, but watching the PDR footage it's reasonable to expect the side bags to deploy during that event.
Like posted, the car is traveling at +50mph when it goes into a spin and loses speed quickly when contacting the pothole. The airbag system works off inertia switches, when more than one sensor signals an event it will deploy the appropriate bags.
01-20-2019, 12:08 PM | #13 |
A great thing about this is that you can see how humans work with their perceptive bias. Owners of the car are less likely to say hey maybe GM should change the rollover algorithm on an advertised track car. Owners that never autocross or track freak out over 1.2g’s like it’s hard to hit. Owners of other makes are sharing similar stories where their airbags didn’t go off.
At the end of the day, I’m not a good track driver (it’s why I took the car to an autocross - to learn)and definitely made a mistake that cost me here. Right or wrong on warranty coverage or not, GM had an opportunity to build goodwill and declined despite the amount of money I’ve spent with them (add a loaded Fifty up with a loaded ZL1 in two years). So at the end of the day, is this likely or common? Maybe not...but does the company care about making it right? Not really in my opinion. It should also help show you how far GM is willing to go to make things right on an advertised track car. Stock engine blows? Sure.... airbags deploy? You’re on your own, just like other members on this forum that have had these curtain airbags deploy on them. Everyone is very quick to justify it happening...let’s hope it doesn’t happen to you, you may perceive things a little differently. I’m not a good track driver but have done far worse in other makes without this happening. Could be luck or with the history that’s developing with these deployments...there could be more to it. You decide next time you strap on your helmet.
It's been fun, done with GM.
2018 Camaro ZL1 (SOLD) - Blown Airbags 2017 Camaro SS F1FTY Member Journal (SOLD) - Bad Motor Last edited by F1FTY; 01-27-2019 at 07:25 AM. |
01-20-2019, 01:02 PM | #14 |
And considering autocross is about the safest auto competitive event (and possibly the most intense IMO)...majority of the sites I've run on are not billiard board smooth. Old runways are the standard or aged parking lots that haven't been maintained in years (since the store/facility closed down allowing the use of that parking lot).
Even well maintained tarmac for aircraft and hovercraft contain expansion joints. In autocross instruction we push the students (especially new drivers) to try to spin the car (generally folks are timid) as there is nearly no danger involved. Worrying about an airbag deploy is one item I didn't think I would have at the back of my head. Hmm...drifting the car and lose vision with a side curtain obstruction is not appealing. |
