01-29-2019, 02:25 PM | #1 |
Drives: 2013 ZL1 Join Date: Nov 2018
Can anyone confirm the FE5(ZL1) uses the same swaybar bushings F&R?
My car needs swaybar bushings, car was riding like CRAP and I found the bushings are bonded/stuck to both bars. From all I can find they are not supposed to be this way.
Bar sizes are 25mm/28mm from what I can find. The only part number I can find is 20942228 and it is listed for both front AND rear. The car is a 5th gen. BTW, no one makes aftermarket bushings for the stock bars that I can find. No I will not change the bars. Thanks a bunch! Last edited by FASTFATBOY; 01-29-2019 at 02:51 PM. |
01-29-2019, 08:02 PM | #2 |
Drives: 02 Z06, 95 Trans Am, 2012 ZL1 Join Date: Mar 2012
It looks like 20942228 has been discontinued. And it appears same part number front and rear.
Bryan 2018 ZL1 M6
01-29-2019, 08:41 PM | #3 |
Drives: ZL1 Join Date: Mar 2018
I just found an Energy Suspension replacement but it doesn’t specify if it’s for cars with the magnetic ride. Might be worth giving them a call.
The Energy Suspension part number is 3.5218G |
01-29-2019, 08:44 PM | #4 |
