02-06-2019, 06:34 AM | #1 |
Drives: 18 ZL1 1LE Join Date: Apr 2013
Used Zl1 1LE anything to look for
I’m trading in my 13 1LE for a used 2018 ZL1 1LE that was a GM corporate car that was never titled. Anything in particular I should be looking at while buying used with this car? Car seems to be in great shape, has 2000 miles on her. Is also a certified used vehicle.
02-06-2019, 06:45 AM | #2 |
Drives: 20 X3M CP & 19 ZL1 1LE A10 Join Date: Jun 2013
I would listen for front end clunk.
🔺22 RS E TRON GT
🔺21 Model S Plaid |
02-06-2019, 07:01 AM | #3 |
Drives: 2013 red Lingenfelter ZL1 Join Date: Apr 2012
Look for tread depth on tires. Should be good if not may have seen a lot of burnouts.
02-06-2019, 07:33 AM | #4 |
02-06-2019, 07:34 AM | #5 |
02-06-2019, 07:47 AM | #6 |
Life's Short, Live Fast!
Drives: 2017 Hyper Blue A10 ZL1 Join Date: Nov 2016
Sway bar end links tend to loosen and cause a clunking sound on some. I've not had this issue on mine. Seems like Nordlock washers are the cure.
Life's Short, Live Fast! https://youtu.be/rTUv2p4T7OA 10.94 at 128 mph, 11.13 at 127mph 870 DA, https://youtu.be/e_X_LcpFp50 11.19 at 127mph 1100 DA, https://youtu.be/OXQiCQdQuH4 11.40 at 125mph 1800 DA
https://youtu.be/uWba1qs8M6Q 11.52 at 123mph 3500 DA TZQPHG '17 ZL1 HBM|A10|Nav|PDR|CFW Hood|ZL1 Mats 12/26/2016 Ordered! 2/8/2017 Built!! 3/2/2017 Brought Home!!! |
02-06-2019, 07:56 AM | #7 |
Front suspension.
🔺22 RS E TRON GT
🔺21 Model S Plaid |
02-06-2019, 09:06 AM | #8 | |
Drives: 2015 Z/28 Black Join Date: Nov 2016
2015 Black Z/28
70 Chevelle SS396 01 M3, 88 Land Cruiser |
02-06-2019, 09:11 AM | #9 |
Drives: 2017 A10 ZL1 KG Join Date: Oct 2014
I would stay away from one with performance mods or the owner talking about how fast he got it.
02-06-2019, 10:03 AM | #10 |
02-06-2019, 10:08 AM | #11 | |
Ok thanks. When I test drive it again, I’ll make sure to listen for anything coming from the front end. It was a GM corporate car so I was told it was either a excuctives car for a short time or it could have been used to go to auto shows with. |
02-06-2019, 11:37 AM | #12 |
Thank you Al Oppenheiser!
Drives: Red Hot A10 ZL1 Convertible Join Date: Jun 2017
02-06-2019, 11:40 AM | #13 |
Drives: 2017 SS 1LE HBM, 2010 SS FBO/Cam Join Date: Mar 2018
Check the edges of the headliner. Some are known to start pealing away.
02-06-2019, 02:15 PM | #14 |
Drives: 2018 ZLE Join Date: Apr 2018
How much?
2018 ZL1 1LE (CARBON/PDR/NAV)
