03-09-2019, 04:44 PM | #1 |
Drives: 2015 1LE Join Date: Oct 2016
Z/28 suspension kit with 1LE F/R sway bars?
I have the Z/28 suspension kit (uninstalled) and wondering if I should keep my 1LE sway bars on or move to the kits smaller ones once installed. Any thoughts or experiences?
03-09-2019, 07:27 PM | #2 |
Drives: 2013 Camaro 1LE Join Date: Jul 2012
I installed the Z/28 suspension with the Z/28 sway bars. With the increased spring rates on the Z/28 suspension the springs contribute a lot more to body roll control. GM could have kept the 1LE sway bar sizes if that would have worked better for the car but they chose to spend more money on different sizes to tune the suspension for better performance.
The one thing some people have done if they want the rear end to loosen up a bit is they have left the rear 1LE sway bar in (it's 1mm larger diameter) to make the car a little more prone to over steer. But I chose to first try the full Z/28 set up to see how I liked it and so far I'm happy with how it behaves. Now you can run the 1LE sway bars and it's not like they car will be undriveable, but the Camaro team had a lot of data and lap times to prove the Z/28 sway bars were faster around the track.
03-09-2019, 09:01 PM | #3 |
03-10-2019, 09:12 AM | #4 | |
03-10-2019, 12:08 PM | #5 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
I have the Z kit, I run my 1LE on the street and I track it.
Originally I ran with the Z front bar with the 1LE rear. Yes, this will balance the car towards oversteer, as expected. But it was a bit harder to put the power down on the exit of corners. RE-71 in 305. I tried the Z front and rear together, definitely felt more "secure". I ran this way for a year. Again with the RE-71's. I then tried to "soften" the Z front bar by lubing the mounting bushings with a rubber compatible lubricant I use at work, Dow Corning Molykote 111. I was looking to get a bit more front bite. As you may know, the OE mounting bushings are designed to be installed dry as the bushing grips the bar super tight, adding to the bars effective stiffness. By lubing the mounts, the bar would lose some of the engineered in stiffness. I ran like this for a year. I stepped up to the ZL1 1LE tire, Goodyear 3R in 305 on all 4. Car had more roll, so this year I'm going to try the front and rear 1LE bars. More roll is not necessarily all bad, but since I have the different bars, I thought I'd experiment. This winter I have also removed the OE 1LE rear diff and I installed a TrueTrac diff, so that will help with putting the power down on the exit of corners.
2022 1SS 1LE A10 BCD WCT+PDR2014 1SS 1LE NPP RECARO SIM-SOLD1995 Z28 M6 GSC PGM-SOLD1975 NOVA COUPE 300HP 350 TH350 FLASH RED-SOLD
03-10-2019, 12:36 PM | #6 |
Drives: 2013 Camaro 1LE 1SS Join Date: Aug 2012
I am putting on the entire z kit too including bearings and rear knuckles on my 1LE and have decided to go z/28 bars too but will leave the 1LE ones for trying things out. My biggest headache is ride height with car so much lighter than a stock car. Uuugh, bout to put it together this month and am freaking out if it will look like a pick up lol. I dremmeled front struts and cut the tips of the knuckle to get camber. On 1LE struts I got up to 2.7 negative this way. I will keep the BMR lowering aprungs as back up but wish BMR made ines in z/28 rates but just lower.
I also wanted to buy the half shafts realizing the grease and boot are onlybdifference (higher temp grease in z/28) since my driver side one burped bad at track last year and greased my wheel very good. I am taking a risk since the damn halfshafts are $350 a pop.
I work for General Motors and am not an official spokes person for General Motors. My views and opinions are my own and not those of General Motors.
03-10-2019, 02:41 PM | #7 | |
03-10-2019, 02:44 PM | #8 | |
I'll slowly migrate over to 19" wheels and tires once I have a couple of sets to use.
03-10-2019, 02:47 PM | #9 | |
03-10-2019, 02:55 PM | #10 | |
On the rear, your alignment guys needs to play with the toe also when trying to get more camber. I do my own alignments and I have achieved -1.3*. I might have gotten more but that is the max I ever wanted. The toe changes with the camber and vice versa. It's a chase, but you gotta be patient.
03-13-2019, 06:55 AM | #11 | |
Drives: 2015 SS/RS 1LE Join Date: Dec 2014
Sorry to hijack, but it's been a really long time since we had a really good discussion on suspension. What about using a ZL1 front bar? Also 19" vs 20" wheels/tires. Referring to the M/T article where they switched the tire/wheels between the Z28/1le. I don't think there is that much to gain as far as it pertains to help in the suspension. I think it helps with braking more, less rotation mass/weight. Tire compound definitely matters. |
03-13-2019, 03:23 PM | #12 | |
The ZL1 front bar is the same as the Z/28 front bar, 25mm. That M/T article did touch on how each car is engineered (damper valving/tires) to work as a cohesive package. The Z dampers are tuned for the Trofeos (among other variables) and 1LE vice-versa. Beyond a tire compound variable, it is the sidewall stiffness too. The sidewall acts as a spring, so this plays a part in the damper tuning. There is one big variable that us guys don't have in running the Z setup, the unsprung weight difference of the Z/28 CC rotors is huge. And the Z dampers are tuned with this mind. I would love to drive a Z/28 to see feel the difference is compared to my 1LE with the Z suspension. My setup is helped with the addition of lightweight Forgelines vs the heavier Z/28 wheels, but those rotors are very light compered to iron. I can tell you with the Z springs/dampers, I can toss the car hard and the transitions are rock solid and stable.
03-17-2019, 09:26 PM | #13 |
I ran 1" bmr drop on front amd 1.25" on rear. Could only get -1.8 front but rear had no issues with -1.5 even when car was stock. Nick something dont smell right that you cant get more..... I cut the slots longer on my 1LE fronts too but the knuckle bottomed out so without cutting the top off i couldnt budge more.
We shall see soon how it will do with z/28s and the mass..... A friend recommended some grinding and cutting of oem components to get the height but we ll see.
11-26-2019, 02:43 AM | #14 |
Did you guys learn/decide anything with your suspension set ups this season?
