03-11-2019, 07:07 PM | #1 |
Drives: Chevy camaro Join Date: Mar 2019
TUNE UP ON 2012 camaro Ls
Hey your guys I AM IN NEED OF SOME HELP!!!!
I DID A TUNE UP (PLUGS AND COILS) ON MY CAMARO AND AFTER THAT WAS DONE I STARTED THE CAR AND I HAD AN MULTIPLE MISFIRE CODE APPEAR ALONG WITH MULTIPLE OTHER CODES. I HAD NEVER ANY ISSUES UNTIL THIS TUNE UP PLEASE HELP |
03-11-2019, 08:10 PM | #2 |
Drives: 2013 L99 2SS Vert Join Date: May 2016
I have no clue but you may want to check your firing order and make sure that wiring is correct and properly installed.
ProCharger Stage II - Stainless Works Headers - Long Pipes & Cats - ZL1 Fuel Pump - Cam On The Way Next Spring
03-12-2019, 09:35 AM | #3 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
There shouldn't have been a need to replace the coils until they go bad. I could see doing routine maintenance on the plugs.
I would take it apart again, and check all of your connections. Something might not be seating correctly, or the spark plugs could be gapped wrong.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
Tags |
camaro5 fest, marolover |
