04-15-2019, 10:49 AM | #1 |
Drives: 2018 ZL-1 Join Date: Jan 2018
I'm confused about the electronic controls on this car
I have read the manual several times, and I still have no real understanding of all the performance nannies on this car.
There is Traction Control, Performance Traction Management, Stability Control, as well as eLSD on the differential. I don't understand the difference. I suppose that in Sport mode, they are all active. But once you select Track mode, you can turn Traction control off with one push of the button in front of the mode selector switch, or turn more stuff off with 2 quick stabs of the button. What happens if you select Track mode, but don't push the other button? What are all these things, and when should I turn them off, or leave them on? Thanks. Mark R. Albuquerque, NM Last edited by Mark R; 04-15-2019 at 11:06 AM. |
04-15-2019, 12:02 PM | #2 |
Thank you Al Oppenheiser!
Drives: Red Hot A10 ZL1 Convertible Join Date: Jun 2017
04-15-2019, 12:31 PM | #3 |
Thanks.
04-15-2019, 02:37 PM | #4 |
Drives: 2019 ZL1 Crush Join Date: Jan 2019
why is that not a sticky?
04-16-2019, 06:41 PM | #5 |
Drives: gas powered Join Date: Jan 2019
Hell I couldnt find the 0-60 timer the other day so dont feel bad.
NOT intuitive controls |
04-16-2019, 07:04 PM | #6 |
Boosted Moderator
It is, in the 6th Gen 1LE section.... Specific Packages / Variants
There are black bars with titles..... The first is Camaro6.com General forums... The next black title bar is the Specific Packages / Variants... It's in there in the 1LE sub-section.... I'm sure you know where this is, but for others looking....
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
04-16-2019, 09:14 PM | #7 |
04-16-2019, 09:24 PM | #8 | |
Steering wheel left control > settings > scroll down to pages > turn on all pages. Exit setup. Then go to the performance section and it will be there.
04-16-2019, 09:27 PM | #9 | |
Drives: 2018 ZL1 Join Date: Oct 2011
2018 ZL1…Many mods to come
04-17-2019, 01:41 AM | #10 |
Drives: '21 ZL1 A10 '08 SRT10 Join Date: Apr 2019
It's very helpful. Almost too helpful. The car is smart for sure. but I hate saying that it's almost too smart, and a bit intimidating to get the settings right and find what works. Too much nanny isn't good in my opinion. In this case there are a lot of nanny's in the daycare. |
