Old 04-20-2019, 10:03 PM   #1
newz
Drives: 2013 ZL1
coolant hose question.
I have a D3 tank and want to install since it is finally warming up. I bought it used and it did not come with the tank to pump hose. Any one know the correct hose type to purchase? The hose looks to be about 2' long. I do not want to cut up the factory hose. Thanks for any info the forum members have
newz is offline   Reply With Quote
Old 04-21-2019, 12:18 PM   #2
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
Inner Di. looks like 3/4.
ZMEnow is offline   Reply With Quote
Old 04-21-2019, 06:30 PM   #3
newz
Drives: 2013 ZL1
ZMEnow thanks for the info. Would you happen to know the spark plug gap for the iridium plugs Ted sells for his 125 hp kit. I believe you have the same kit.
Old 04-21-2019, 08:01 PM   #4
ZMEnow
You can look them up under the NGK page, they all pre gap at .040
Product Attributes
Center Electrode Core Material: Copper Core
Center Electrode Tip Material: Iridium
Ground Configuration: Standard
Ground Electrode Core Material: Nickel Core
Ground Electrode Quantity: 1
Ground Electrode Tip Design: Taper Cut
Hex Size: 5/8"
Insulator Height: 53.00 mm
Manufacturer Heat Range: 7
Pre-Gap Size: 0.040 in
Reach: 0.708 in
Resistance: 5000 Ohms
Seat Type: Tapered
Thread Diameter: 14.00 mm
Old 04-22-2019, 07:37 PM   #5
newz
Drives: 2013 ZL1
ZMEnow Thanks for the info. Checked two spark plugs yesterday and they are both at 0.040 in. I have read that some people went to 0.033 in when they changed to 18% lower pulley. Checked with Autozone and a couple more patrs stores and they don't have hoses rated the same as our CAC hoses are. Will look on AMAZON next they have everything :-).
Old 04-22-2019, 08:14 PM   #6
ZMEnow
Every part I have modded I have ordered the OEM part/nut/bolt/gasket, and bagged it for restoration. So since you have to cut the hose from the SC, i,ordered it new. It only comes with the clips and is over 100 bucks.
Old 04-25-2019, 01:13 AM   #7
newz
Drives: 2013 ZL1
ZMEnow Will have the part on order through a dealer this week.
Old 04-25-2019, 10:52 PM   #8
ZMEnow
Surprised in Ohio you cannot find that hose as it has no pressure on it. I would be checking either some one that supplies hoses for large semi’s or pressure washer applications. Did you go to an O Reilly’s?
