| Tuning / Diagnostics -- engine and transmission Tune and diagnostics for engines and auto transmission. |
Thread Tools |
PRESIDENT CALIBRATOR JRE
![]() Drives: YELLOW 2013 ZL1 AUTO Join Date: Jun 2009
Diablo Custom Tune What you need to do to get one
When you Purchase a Predator or Trinity From Me you get a Tune for free for your mods, exclusions apply.
You will need to install one of the tunes that came with the Trinity or Predator if you have not done so. Using this software http://diablosport.com/CMR/software/...er_2.2.1.7.exe Then, Extract the Last Tune Written, and the Original back up, save them to your desktop so they are easy to find. I have created Dyno and Track tested tunes for all of the Product we sell so in most cases you will NOT need to datalog Unless I instruct you to do so. If I instruct you to datalog and send me the logs here is what you do. Using your Trinity or Predator, You will need to set up your datalogging, I want you to select the following RPM, ENGINE SPEED ECT ENGINE COOLANT TEMP TPS THROTTLE POSITION , SOMETIMES TPS ABSOLUTE IAT INTAKE AIR TEMP MAF MASS AIR FLOW GRAMS PER SECOND TIMING SPARK ADVANCE Knock Retard Short term fuel trim bank 1 Short term fuel trim bank 2 Long term fuel trim bank 1 Long term fuel trim bank 2 Go find a open road somewhere, 1/2 mile or so long would be great, from a stop drive the car 1/4 throttle up through the gears normally shifting at about 4500 RPM. Then repeat at about 1/2 throttle to 5500 RPM Then Repeat at Full Throttle 6000 RPM, a 1/4 mile is sufficient. This can be done all in one log in most cases. Using this software http://www.diablosport.com/CMR/softw...er_3.2.0.7.exe Extract and save the Datalog to your desktop. Email me the 3 files along with a list of Mods, your name and address, Car you have, and a phone number where you can be reached easily. Ted.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs! Ted Jannetty Jannetty Racing Ent Inc. 2984 East Main St. Waterbury Ct. 06705 203-753-7223 tedj@jannettyracing.com www.jannettyracing.com www.turboaddictionparts.com Performance Parts Last edited by JANNETTYRACING; 05-09-2010 at 05:48 PM. |
![]() ![]() Drives: 2010 Camaro, 2SS/RS Join Date: May 2009
Ted, if we buy the diablo programmer from you, do we get a discount on the tuning??
2010 2SS/RS CGM American Racing Headers, Magnaflow axle back, Roto-Fab CAI, Audio Integrations Sub box, Alpine Type R 10, Alpine MRP-500 amp, Pro Clips iPhone Mount |
Yes you do.
Please vist our web sites for all your performance needs! Ted Jannetty Jannetty Racing Ent Inc. 2984 East Main St. Waterbury Ct. 06705 203-753-7223 tedj@jannettyracing.com www.jannettyracing.com www.turboaddictionparts.com Performance Parts |
![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 1SS Join Date: Aug 2009
How much $ ?
2010 Camaro 1SS Inferno Orange Magnusson Supercharger Installed and Tuned by ADM Performance, Roto Fab CAI IOM painted, MBRP Cat Back Exhaust, Barton Industries Short Shifter, Clear Image Headers, Pedders coilovers, BMR Front/Rear sway bars Trailing Arms and End Links, VMax ported TB
Ted, I installed the trinity I purchased from you on my 2010 camaro (CD in box was blank so I downloaded all updates from diablosport website). tried the performance tune, it caused several trouble codes including stabilitrac, cruise control, abs, brakes, and three unknown codes any help or ideas would be appreciated. I put it back to original tune first time same codes, did it again and while origonal tune is on car no trouble codes
#6 | |
#7 |
#8 | |
![]() Drives: 99 Z28 Join Date: Nov 2009
Maybe disconnect the battery? |
#9 |
TTT
#10 |
A lot of request so bump to top.
#11 |
Serious Sleeper
Drives: 2010 CGM 2SS/RS M6 Join Date: Nov 2008
Ted, You sure are a good dude to have here on camaro5.
Drive-by Fact of Life: After Monday and Tuesday even the calendar reads... W T F ![]() *************************************** |
#12 |
![]() Drives: 2010 Camaro 2SS Join Date: Mar 2009
Hey Ted,
How does your custom tune compare to using DSLogRedux to modify parameters and 'dial in' to the correct parameters? I've tried using DSLogRedux, but ultimately have gone back to the canned Diablo tune because the car seemed to be running a little too rich for everyday driving. However, with the canned tune it seems to be a little on the lean side. For daily driving I prefer running a little lean to save on gas. The canned tune seems to hold the AFR to 14.75 except at WOT. At WOT the AFR goes to about 12.9ish. -- Wes |
#13 | |
I would need to see your datalogs to see if there is any room for improvment. Ted.
#14 |
Bump for the Newbies.
We can now do all this with SCT as Well. Ted.
#15 |
Serious Sleeper
Ok here is a hypothetical question, How close is a data logging diablo custom tune to a dyno tune in terms of horsepower????
#16 |
I'm not totally useless..
Drives: 2010 SIM 2SS/RS A6 SC LPO Rallies Join Date: Sep 2009
someday I will need this!!
#17 | |
If you can provide me Wide band O2 readings at WOT Spot On.
#18 |
Serious Sleeper
Thats all I needed, when my camaro says its ready, you will have my money for a diablo sport and a tune. The ck eng light is all I'm waiting on because of long tubes.
#19 | |
Drives: 2006 Monte Carlo SS Join Date: Jul 2009
first issue we've hear of where someone said their vehicle was running rich after making the correct adjustments... you can email me the log files to look at if you would like... thanks! |
#20 |
Just installed the Predator 91 octane tune tonight. First, let me say, it was harder pulling the fuses than it was putting in the tune. Second, it couldn't have been easier to install the tune. Now, I have to find the time to do the data logging, so I can get a custom tune.
#21 | |
#22 |
Can you do this with a Predator? Or is it only possible with the Trinity?
#23 |
Wideband O2 Sensor plugged into the Trininty
#24 |
SoCal C5 Family Member
Drives: 2SS/RS IBM M6-when she lets me Join Date: Oct 2009
Help - I lost 40hp
Hey Ted, I desperatly need your help. We purchased an LS3 for my wife and we Love this car, we had no plans of doing any mods but things happen. Thanks again for doing the Cold Air Intake test, that was all I needed to sell the wife on the CAI intake. We also ended up getting a Borla axle back, but the car is basically stock. Yesterday we dyno'd 5 stock Camaro's, 3 of the cars had from 373 to 384 rwhp, which is what I have seen on several other stock Camaro's. 2 of the car's got 343, ours was one of those and even worst was the second pull, 335. I am freaking out and I am worried something might be wrong. So the big question is which one of the Diablo programmers will best help me diagnose the problem. I also have several questions about this, will a tune help if I plan to keep the car basically stock? Could the Low Octane fuel table cause me to lose 40hp? Does the "fuse pull" do anything for an LS3, or do you have to disconnect the battery, and for how long? I have attached our dyno sheet, one of the ugliest I have ever seen. I would greatly appreicate any input or words of wisdom and, Thank You for all that you have done for the Camaro Community! Have A Great Day!
:flag2:
Hurst Short-throw Shifter, CAI Intake, Borla ATAK Cat-Back Exhaust, Hotchkis Race Pack Sport Suspension |
#25 | |
Just because you bought 93 Octane does not mean you received 93 Octane. With our current economy a lot of people are not buying super unleaded and are stepping down, so, Super Unleaded sits in the tanks for months and goes bad. Ask your local station how much super they sell and find one that sells the most to assure a fresh tank of Super every time. A Predator, a Trinity or an SCT X3 Can datalog all your sensors and you would be able to see where your timing is running and how much knock is detected. Give me a call I will set you up. Ted.
| Thread Tools | |
| Official 1/4 Mile (V8) 2010+ Camaro Fast List | Merc | Dragstrip, Tracking, Autocrossing, Driving Techniques Discussions | 2118 | Today 07:52 PM |
| Unofficial 1/4 Mile 2010+ Camaro Fast List | Merc | Dragstrip, Tracking, Autocrossing, Driving Techniques Discussions | 210 | 06-13-2013 08:42 PM |
| CAI intake + noweeds.net + custom dyno tune by Livernois Motorsports! | AdamCzap | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 6 | 11-17-2009 10:37 AM |
| Calling 2010 Camaro Owners - Get a free custom dyno tune! | SCT | V8 Bolt-Ons & Tunes | 9 | 09-03-2009 11:23 AM |
| LS3 goes 11`s Bonestock! | GMRULZ | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 28 | 12-08-2008 09:10 PM |
