06-23-2019, 05:03 PM | #1 |
Svt lol
Drives: 2011 ss inferno orange blown Join Date: Jan 2012
What gears you running?
What gears are you 800+ rwhp guys running that drag race? Right now I’m at 700rwhp and run 3:91 gears. I think they’re a bit much for where I’m at now I’m know they’ll be to much when I upgrade the Procharger head unit. I want to go down to 3:45 since I’m sticking with the stock diff housing.
06-23-2019, 05:18 PM | #2 |
'It's an experiment'
Don’t drag (I do road course) but 3.45s were the max for me @ 600 RWHP. I’m over 800 now and still have the 3.45s. Should have kept my 3.27s (I’m auto) so first gear would not be a waste :o)
-Don
747 RWHP 794 RWTQ
06-23-2019, 05:41 PM | #3 |
Drives: Camaro Join Date: Aug 2015
3.23s, I'm at 630 now but will be 800 plus first of the year. I spin as it is on the streets with radials so that is why I went with that over the zl1 3.73. 3.73 may be better on a prepped surface right up to 800 but we all know you'll want more later and I think the 3.73 will become too much. If your Auto anways we already have a short first gear and some will start in 2nd.
06-23-2019, 06:06 PM | #4 |
Svt lol
I have a 4l80 in it so I know the gears are worlds apart from anything that are in there factory.
06-23-2019, 06:45 PM | #5 |
Served USN - Atomic Chimp
Drives: 2021 Camaro ZL1 1LE A10 (stock) Join Date: Jul 2012
I had 3.73 and 3.23 with 750whp, preferred the 3.23. I have 3.25 and over 950whp now. I wouldn't do anything less.
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
06-23-2019, 07:30 PM | #6 |
Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
850whp here. Going back to be retuned for 6-8 more psi Wednesday. Th400 trans,4.10 and 32.6" tall tires. Would be comparable to a 3.50 and 28 tall tire.
06-23-2019, 07:35 PM | #7 |
Drives: G8 Join Date: Mar 2012
I have an M6 G8, which had 3:70s and I really liked them with basic boltons. Went turbo, drove for a bit at 600?hp and 3rd would light up at 80+mph...kinda fun? Went down to 3:45s and it's a lot better at 700hp. 6th isnt usable around town but that's ok. I'm now thinking about going down to 3:23s with a ZR diff.
Sent from my Pixel XL using Tapatalk |
06-23-2019, 10:00 PM | #8 | |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
With 315/50x17, my effective ratio is 3.50. Works well for drag racing. With street radials, it fun to light them up at 80. But make sure you drop it out of OD into D or you will fry your sprag. |
06-23-2019, 11:15 PM | #9 |
2010 transformer
Drives: 2010 ss camaro Join Date: Nov 2014
806 rwhp and 3.23 gears and feels great
2010 transformer, vertical doors, 315nt05 rears, pedders supercar coilovers, hotchkis sway bars, links, adjustable, toe bars, bmr poly cradle bushings, 1le control arms, bmr tunnel brace, bmr subframe connectors. Cam 227/239-623-620@114 Mast medium bore heads, sw 1 7/8 headers, cat delete, x pipe, 3" dynomax true duals, fuel rails, fast 102 intake and NW 102 throttle body, catch can, rotofab cai, shifter, raptor custom shift light. Dss drive shaft, 3.91 gears. 492 rwhp
06-24-2019, 11:31 AM | #10 |
06-24-2019, 02:16 PM | #11 |
Drives: 2015 Camaro SS commemorative Join Date: May 2015
all I have ever asked is to see ONE car in the 8's with a 3.23, I am a 3.23 now and its too steep. 3.50 would be perfect if it existed.
2015 Camaro SS, LS3 Stroker, PRC heads,CUSTOM CAM. AGP 68/68 with custom Hot and Cold side. Fore triple pumps, Holley terminator X. BMR drag suspension with carlyle brake kit. 15" ET drags and 17" skinnies. ZL1 3.73 gears , aluminum driveshaft. TH400 with circle D converter.
06-25-2019, 09:06 AM | #12 |
Ray - they exist in the 9” world, Ray
06-25-2019, 11:01 AM | #13 |
Drives: Miss Con Ception Join Date: Aug 2016
The LS3 comes with a 3.45. A bit shorter tire and...
2011 1SS/RS LS3 CGM
06-25-2019, 11:21 AM | #14 |
He's talking about something that can actually hold power like the zl1, 9", s60, 12 bolt
