07-07-2019, 10:46 PM | #1 |
Am I Cammed?
I’m the second owner of an 10’ SS and I can not tell if the previous owner has an aftermarket cam in this car or not. Is their a way to check without taking it out?
I’ve noticed and have been told by others that the car sounds choppy and I thought so too. Maybe these cars naturally sound choppy, idk. Axleback exhaust and headers make it more noticeable. I bought a cam package and don’t want to change it out if I already have an oversized cam in it already. I can tell the previous owner had headers as well due to the o2 sensor extensions lol.... Also I notice the car really doesn’t have any buck or surging like most complain about when camming. It isles at about 800-900rpm I believe and have no driving struggles. Maybe I’m just used to it? The car also shakes a tiny bit at idle. Back and forth. Any thoughts? |
07-07-2019, 11:16 PM | #2 |
Drives: 2011 2ss/rs black with white rally Join Date: Apr 2012
a video with sound might help
07-08-2019, 01:55 AM | #3 |
Drives: 13' 1LE Join Date: Apr 2012
Cammed are quite faster than stock. Id say youd def kknow. They sound a bit cammed stock..a bit
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
07-08-2019, 06:28 AM | #4 |
Drives: 2015 1LE Join Date: Oct 2015
does it idle rough?
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
07-08-2019, 07:46 AM | #5 |
07-08-2019, 07:47 AM | #6 |
07-08-2019, 08:17 AM | #7 |
Drives: 2014 Chevy SS Join Date: Nov 2014
How would he know that the car is cammed if he has nothing to compare it to?
-------------------------------------------------------------------------------- FREY, You can take this any way you want.....but IMO, you cannot properly build around a cammed engine if you don't know the specs of that cam. Best of luck.....whatever you do! KW
1995 Impala SS -- Heads/Cam LS3
1996 Impala SS -- 398ci LL Solid Roller LT4 2014 Chevy SS --- 429ci Hydraulic Roller LS3 |
07-08-2019, 10:19 AM | #8 |
weSS1LEy
Drives: 2015 camaro 2ss/rs/1le Join Date: Sep 2015
You might have a tune with some ghost cam effect.
Rotofab, arh no cats, atak, elite cc, 94 octane tune, Mobil 1, phastek scoop, custom cam 230/243 .621 .604 114+4, related cam kit stuff. 470/435 rwhp/rwtq
07-08-2019, 10:55 AM | #9 | |
07-08-2019, 11:58 AM | #10 |
Drives: Camaro Join Date: Oct 2018
07-08-2019, 12:02 PM | #11 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
The stock cam has some chop to it, especially with exhaust work done.
More to come. |
07-08-2019, 12:11 PM | #12 |
weSS1LEy
OP I had the exact same thing. Can’t remember about when it was stock but definitely after headers and tune it had a little lumpy idle. I remember my mother asking what was wrong with my car? Lol. I said big powerful engine! I’m sure my tuner put a bit of ghost cam effect in but I think it would do that a little anyway
07-08-2019, 12:15 PM | #13 |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
If you want to know for sure you could get a dial indicator, pop a valve cover and measure valve lift.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
07-08-2019, 01:56 PM | #14 |
Drives: 13 IOM 2ss RS manual Join Date: Jun 2018
Exactly what I would do, if you find it have a different lift than stock, then you would want to take a look at the end of the camshaft itself, should be some info there to find the specs, and who made the cam. Good luck.
Rectangular Dollars will beat Cubic Inches
