08-04-2019, 08:22 AM | #1 |
weSS1LEy
Drives: 2015 camaro 2ss/rs/1le Join Date: Sep 2015
Anyone using a vortech?
I notice the vortech has the air intake in the front whereas procharger has it towards the rear of the engine compartment. Front seems better but I know procharger is highly reputable brand
Rotofab, arh no cats, atak, elite cc, 94 octane tune, Mobil 1, phastek scoop, custom cam 230/243 .621 .604 114+4, related cam kit stuff. 470/435 rwhp/rwtq
08-04-2019, 04:45 PM | #2 |
2010 transformer
Drives: 2010 ss camaro Join Date: Nov 2014
Procharger tested it in front. Too much air blockage. I run the pro filter with 806 rwhp. On biggest pulley.
2010 transformer, vertical doors, 315nt05 rears, pedders supercar coilovers, hotchkis sway bars, links, adjustable, toe bars, bmr poly cradle bushings, 1le control arms, bmr tunnel brace, bmr subframe connectors. Cam 227/239-623-620@114 Mast medium bore heads, sw 1 7/8 headers, cat delete, x pipe, 3" dynomax true duals, fuel rails, fast 102 intake and NW 102 throttle body, catch can, rotofab cai, shifter, raptor custom shift light. Dss drive shaft, 3.91 gears. 492 rwhp
08-05-2019, 12:56 AM | #3 |
I ran my Paxton(same as Vortech) both ways. Rear is fine
08-05-2019, 04:39 PM | #4 |
weSS1LEy
Interesting. Looks good I just thought the back would be unnecessarily hot but seems not to be an issue
08-05-2019, 04:46 PM | #5 |
I have a V3 with the filter in the front. Would it be better to more it to the back or it the same either way?
08-05-2019, 08:12 PM | #6 |
I had a lb or so more boost taking the elbow off.
