08-15-2019, 06:43 AM | #1 |
Drives: 2017 Camaro ZL1 Join Date: May 2018
LSA Conversion Camaro LT4 SC Reservoir Install
Does anyone have install tips or pictures of the LSA Conversion Camaro LT4 SC Reservoir? I just got one and there are no instructions with the kit. The link to this kit is here: https://lsa-conversion-store.myshopi...sivoir-upgrade
08-15-2019, 06:46 AM | #2 | |
@zle_blackwing
Drives: 2018 ZL1 1LE Join Date: Mar 2017
2018 ZL1 1LE - Red Hot, Nav, PDR
08-15-2019, 01:30 PM | #3 |
Drives: Anything I want Join Date: Oct 2008
Here ya go
Install the 90 degree 3/4 inch rubber hose to the bottom barb facing forward. Forward is the same as the resivoir barb position when installing it to the bracket
Mount the bracket and resivoir to the stud on the driver side shock tower using the original mounting nut that currently holds the ac line bracket,leave the ac line bracket in place. Unplug the factory Intercooler hose fitting (remove purple clip and save) that is rearward most on the supercharger (also has an arrow Embossed in the casting showing flow out from the supercharger) Now that it is unplugged you can loosen the clamp and remove the FACTORY FILL fitting from the hose and discard it. Install the purple clip that you removed that allowed the the connector removal into the hose fitting that is 90 degree and snap it into the supercharger. Now take the other end of that hose and attach it to the resivoir barb that should be facing forward and tighten the supplied worm gear clamp.Like the pic on our website Install the bottom hose from the resivoir to the existing hose that you removed with the supplied clamps and position it away from the headers or exhaust manifold. Fill the resivoir with dexcool or water. Start the car with the cap removed and wait 10 sec for the pump to reach full speed and top off. Put the cap back on. Your done |
08-15-2019, 01:33 PM | #4 |
Here are more - But some are old
Some old,Some new.....The understanding is clear though.
https://www.camaro6.com/forums/showt...hlight=coolant https://www.camaro6.com/forums/showt...hlight=coolant |
08-16-2019, 10:18 AM | #5 |
Pics of the parts being installed
Here are pics that should aid as well.
08-16-2019, 01:29 PM | #6 |
@viurniel
Drives: 19 ZLE A10, 15 2SS, 90 300ZXTT Join Date: May 2016
This is great, but you guys should really turn this in to a 1-2 page instruction manual.
08-16-2019, 03:15 PM | #7 |
Drives: 2019 ZL-1, Shadow Gray, Sold Join Date: Jan 2019
I could not agree more! The mod is relevant, and by all accounts needed! I have been hesitant to make the purchase because of limited instruction information and some folks having difficulty with the install. ADM says it is a 10 minute install.
Maybe someone might take the time to make a step by step with appropriate pics and the particular hose/part highlighted/circled would be a great help to all. Just MHO. |
08-16-2019, 08:27 PM | #8 | |
Drives: '21 ZLE A10 Join Date: May 2012
08-16-2019, 11:10 PM | #9 |
Drives: 2016 Challenger Hellcat, 2018 ZL1LE Join Date: Dec 2009
Better yet, it should be made into a sticky thread !!!!
2016 Challenger Hellcat /B5 blue/Sepia interior/Brass Monkey Wheels/
2018 ZL1 1LE/Red hot 2019 Shellby GT 350R/ Oxford white/ Matte Black Stripes/ Carbon Fiber Dash/ Electronics Package #413 |
08-27-2019, 05:48 AM | #10 |
Sounds good
Ok will make this happen
08-29-2019, 07:47 PM | #11 |
Guide in the box
Its all done now. Each box will have a guide with photos.
Thanks Andy |
08-29-2019, 10:58 PM | #12 |
Drives: 2020 White ZLE A10 Join Date: Jul 2019
I just ordered one. Lets hope it comes with some good instructions because...Imma need some details.
08-30-2019, 08:04 AM | #13 |
08-30-2019, 10:56 AM | #14 |
Thanks Andy......you da man!
