09-23-2019, 01:48 PM | #1 |
Drives: 2016 2SS Nightfall Grey Join Date: Mar 2016
Battery Drain
Good afternoon everyone.
My Wife's 2016 2SS must have some sort of parasitic battery drain going on. The car is just under 3.5 years old from our purchase date and if I replace the battery again, this will be the 4th battery in under 4 years. We did have an issue with the electronic parking brake which the dealer installed some pigtail harness to bypass the shorted section of the harness if I remember correctly. Other than NPP rattles the car has been without issue. Recently I have been keeping a trickle charger on the car but even doing that it is slow to start after a few days. I have read the TSBs posted about OnStar potentially being an issue. Short from taking it back to the dealer and dealing with their BS does anyone have any suggestions? Thanks in advance! |
09-23-2019, 01:51 PM | #2 |
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C) Join Date: Jun 2017
I haven't started my car in over 2 months and for some reason it starts up as if i drove it yesterday, quite surprised you are having an issue that consistently with your batteries. I hardly drive my car, i'm just waiting for the day the battery gives for the lack of use.
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw |
09-23-2019, 02:07 PM | #3 |
Retired from Car mfrs....
Drives: 2LT RS/HR-V Join Date: May 2013
After your second battery, why would you continue to just buy batteries?… Obviously you have a parasitic drain… Somewhere… these new cars do take some current out of the battery when you’re not using it, but because any car company needs a batt to last longer in the storage lot at an airport for a couple weeks, otherwise the entire industry would have a huge problem.
Find a new dealer, and find the drain. |
09-23-2019, 02:25 PM | #4 | |
I think I'll take it to our usual dealer down the road and see what they say before traveling further. |
09-23-2019, 02:26 PM | #5 | |
09-23-2019, 10:24 PM | #6 |
Drives: 2016 Camaro SS Join Date: Aug 2019
Have you been experiencing the slow crank when the car starts as well? My starter was draining my battery due to the heat in FL when consecutively starting the car within minutes or even hours. Ended up being a blown fuse by the battery terminals, and had to install an additional ground wire to starter bolt. No issues since
10-01-2019, 05:15 PM | #7 |
Drives: 2016 2SS w/chrome blue stripes Join Date: Aug 2009
I too am suffering this issue. Dealer cannot find what's wrong. Car has left me stranded so many times, I've bought a jumper pack...which I've used too many times. Kyleef210 can you tell me specifically where to look for a blown fuse? And LoJac963 please let us know how this is resolved for you too. thanks all
PS - I found this other thread about a bad belt tensioner causing charging issues for the battery... https://www.camaro6.com/forums/showthread.php?t=549163
2016 2SS Chrome Blue Stripes
10-01-2019, 06:45 PM | #8 |
Drives: 2016 1ss camaro Join Date: Feb 2016
mine is a 16ss and i had mine replaced under warranty earlier in the year and i only drive my car on the weekends pretty much lol have about 26k miles on her now
10-02-2019, 08:38 AM | #9 |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
OP is the car bone stock, and I mean bone stock with zero modifications or adds on of any sort electronic or electrical wise?
2019 Corvette Z06 2LZ A8 - Halltech CAI, AWE non-catted X-pipe, Mamo V2 ported TB 592rwhp, bone stock 566rwhp
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD |
10-02-2019, 08:59 AM | #10 | |
Drives: 2016 Camaro 2SS Convertible A8 Join Date: Apr 2019
10-02-2019, 12:18 PM | #11 |
I found the starter fuse (F13) that was mentioned. Check this diagram. It's the fuse box on top of where your battery terminals are. Mine was not blown. Here's the link to the diagram https://www.camaro6.com/forums/showthread.php?t=484525
10-02-2019, 12:38 PM | #12 | |
Drives: 2016 Camaro 2SS Join Date: Jan 2015
I've heard that others have added a second ground that has helped but after many searches I can't find if this is actually a permanent fix or not. |
10-02-2019, 12:45 PM | #13 |
I noticed the other day that when driving, the battery gauge reads 13.5 or 14. This is good. Then another day it read 10.5 or 11 the whole 15 mile drive and then wouldn't start the next try. Looks like it isn't charging (some of the time). The alternator and battery were said to tested fine.
10-02-2019, 12:52 PM | #14 | |
