10-12-2019, 07:57 AM | #1 |
Drives: 2022 Kia Stinger GT2 Join Date: Oct 2019
Storing Summer Tires in a Non-Heated Garage
I live in an area that frequently has below freezing temperatures in the winter (at the very least).
I have a garage, but it isn't heated. If I store summer tires in my garage, will I run the risk of having them damaged when the temperature gets too cold? I know that they are not recommended for driving under a certain temp, but I'm not sure if that applies to storage as well. Thanks |
10-12-2019, 08:01 AM | #2 |
Drives: Chevy Camaro Join Date: Jul 2019
Spray the tires with Aerospace 303 and wipe them down. it will keep the tires from dry rotting stuff is amazing.
10-12-2019, 08:29 PM | #3 |
Drives: 2017 50th Anniversary Camaro SS Join Date: Jun 2017
My Camaro has been stored outside the last two winters and I've had no issues with the summer tires come spring time.
2017 50th Anniversary Camaro 2SS
2016 Chevy Malibu LT (wife's car) 2004 Chevy Impala (winter car) 2001 Chevy Camaro SS (sold) 1969 Chevy Suburban (restoration project) |
10-14-2019, 10:19 AM | #4 |
Drives: 2018 SS - 2015 SS 1LE - 2013 SS Join Date: Aug 2013
Never had a problem storing in Michigan, which gets much colder than PA. You will be safe to park it and hang up the keys for a few months.
Billy B.
Current: 2018 Hyper Blue SS |
10-14-2019, 10:22 AM | #5 |
Drives: Kubota 2640, 83 BMW R-65, 2017 1 SS Join Date: Nov 2016
IIRC they state to not DRIVE or MOUNT when below freezing. The disclaimer I read stated that before MOUNTING tires that had been subjected to freezing temps to allow them to warm for 24 hours. Nothing about long term damage.
10-14-2019, 11:26 AM | #6 |
Drives: HB 2SS Join Date: Apr 2017
I've stored it for 2 years with no cracking and that's while it's still on the car too. As long as the tires aren't being used / driven on then it's good.
10-14-2019, 12:07 PM | #7 |
Drives: Fast if no one's looking Join Date: Aug 2019
Hit 'em with a blowtorch like they do in the pits at NASCAR before every race
10-14-2019, 01:24 PM | #8 |
Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
I stack mine in the garage next to an interior wall and throw a big moving blanket over them... they stay much warmer that way, and no issue for me living near Denver, CO... which isn't really that cold anyways.
10-14-2019, 02:21 PM | #9 |
Drives: rally green LT1 manual Join Date: Jul 2018
The problem is the tire compound (or portions of it) can enter the glass phase at below freezing temps. The compound (or portions of it) can then crack or break if flexed or pressure is applied. The tires should be allowed to warm slowly (24+ hours) before mounting or use. Just storing them in the cold won't hurt them as long as they aren't moved until thawed.
10-14-2019, 02:22 PM | #10 |
Drives: 2017 2SS A8 NGM, 2012 Yamaha FZ8 Join Date: Jan 2017
I think that's what I'm doing this year. Hate carrying those things up and down my basement steps. My summer tires are about shot anyway.
10-14-2019, 05:42 PM | #11 |
Drives: like an old lady Join Date: Jun 2012
eh i put my other set of goodyears in the corner of the dining room. with that being said, my detached garage isn’t heated. the car sat out there all last winter, tires were fine.
2016+ camaro: everyone’s first car
10-15-2019, 01:42 AM | #12 |
you have the factory tires. they will be fine being stored on the car in the winter just dont drive on them below 30 or so. if you have aftermarket ultra summer tires then you dont want to store most below 20deg. Ill be keeping my pilot super sports inside the house in the winter.
10-15-2019, 08:51 AM | #13 |
Drives: 2017 2SS, 50th pkg, M6, MRC, NPP Join Date: Jan 2016
As others have said, you will probably be fine. If this garage is part of the house like mine (but not heated), it rarely gets below 40 even on the coldest days.
