11-26-2019, 10:00 AM | #1 |
Drives: 2012 Silver ZL1 M6 Join Date: May 2019
Long Tube Question
SMG is having a good Black Friday sale on TSP Long tubes.. Only 549 which is a damn good price. I was told they are 2" but I feel people said go 1 7/8. Just wanted to confirm what most people are running? Also if I got that route is there anything else I should buy??? If I recall the stock plug wires may not have clearance with the 2'. If needed any part numbers would be great I believe they come with free heat socks
2012 Chevy Camaro ZL1 M6 504whp/517tq
1997 Honda Accord AKA Beater with the heater. The daily 2015 RAM 1500 (sold) 2014 Mustang GT bolt ons and spray (sold) Last edited by jvervoren; 11-26-2019 at 10:23 AM. Reason: Update |
11-26-2019, 12:27 PM | #2 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
Go with the 2" option if you don't already have headers. They won't hurt you now, and will make a little more power if you ever start getting into the 700-800+rwhp range.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp // CSP LT's & Ultra Cats // Elite Ultra CC // BMR MM
Past Rides- 2014 ZL1 M6 Red Hot | Tons of mods 2004 CTS-V M6 Silver | Many mods 1995 Corvette M6 Torch Red | A few more mods 1992 Camaro M5 White | A few mods |
11-26-2019, 01:34 PM | #3 |
What about clearance with the plug wires? Will I need to go aftermarket plug wires with 2'?
1997 Honda Accord AKA Beater with the heater. The daily 2015 RAM 1500 (sold) 2014 Mustang GT bolt ons and spray (sold) |
12-02-2019, 02:45 PM | #4 |
Drives: 2013 Chevrolet ZL1 Join Date: Oct 2019
I have 2" headers with stock everything else and no clearance issues.
12-02-2019, 05:09 PM | #5 |
Drives: 2013 Zl1 Join Date: Feb 2019
Going to a higher temp wire is recommended. The larger amount of heat will at some point cause an issue.
12-07-2019, 10:50 AM | #6 |
We usually recmomend the 2" on the ZL1s. They fit just fine on the 5th gen you might have to ding one of the pipes for a little clearance here or there but nothing crazy. Aftermarket wires are not needed but if you do decide to grab a set we always recommend a set of boot protectors.
12-07-2019, 11:40 AM | #7 |
Drives: 2015 SS/RS 1LE Join Date: Dec 2014
Definitely go 2". I used the stock wires, no problems. I did have to dent one primary to clear the steering shaft. Super easy to do. If you are installing yourself, put the header in, mark the area of the tube next to the steering shaft, pull it back out, dent it with a mini sledge and a big deep well impact socket. Easy. You need a good 1/2 to 3/4" clearance.
12-07-2019, 07:32 PM | #8 |
Drives: 2013 ZL1 A6 Camaro Join Date: Jun 2013
Im curious if I have to "ding" a pipe because it might make contact. How much of a "ding" do I have to make when the engine torques and twists?
Thats why I when with 1 7/8 to prevent "dinging" and getting false knock from rubbing/contact .
2013 ZL1 Camaro A6. ARH Headers, K&N intake, Tuned by Tampa Tuning
2014 V6 Camaro bolt ons and E85 Tuned by Tampa Tuning |
12-07-2019, 09:32 PM | #9 |
Drives: ZL1 Join Date: Oct 2012
I have the American Racing Headers in 2 inch they fit perfect and required no dinging or modifying for clearance.
12-07-2019, 09:44 PM | #10 |
There is about 100 pages on "custom fitting" headers. Some move the motor, some "ding" the pipe, some send the headers back. Most fit, but some(all brands) need to be modified a tad. Mine was good if I was going straight but soon as I made a left turn(?) it would hit the steering shaft. It's not a big deal even some want to make it one. A minimal dent works, 1/4 to 3/4". It's not like it has to be crushed to half the diameter of the pipe.
12-30-2019, 11:32 PM | #11 |
Drives: 2013 Chevrolet Camaro ZL1 Join Date: Jul 2019
Did anyone keep the belly pan after installation of headers?
12-31-2019, 07:57 AM | #12 |
Drives: 2013 ZL1 M6 Join Date: Sep 2016
I still have the belly pan installed on my car. Just needed to notch it a little at the collector.
Fast 850cc Injectors, ATI Balancer, 8.66 Lower Pulley, 2.55 Upper Pulley, Lingenfelter CAI, Kooks LT with cat delete pipes, Noweeds Exhaust Cutouts (extremely loud under full throttle), BTR Stage 3 Cam, BTR Platinum 660 Valve Spring Kit, TR7ix Iridium Spark Plugs, Lingenfelter Solid Isolator, 160 Degree Thermostat, Larger SC Coolant Reservoir with Hose Relocation Kit, BMR 1.25" Lowering Springs, MGW Short Throw Shifter, Racing Brake 2 piece rotors front and rear, Starkweather Performance Custom Dyno Tune on 91 Octane.
691.38 RWHP 630.35 RWTQ |
12-31-2019, 08:36 AM | #13 |
Drives: 2015 Camaro 2SS Green Flash Edition Join Date: Dec 2015
I have installed Kooks 1-7/8 headers on multiple 5th Gens with no clearance issues. And I have added a factory Z28 belly pan and have not experienced any header clearance problems.
Kooks stepped headers & Solo XL Cat-back
ADM CAI w/race scoop & Rotofab w/w relo GPI VVT SS1 cam and CNC ported heads milled .30 BTR .660 springs, Straub solid bushing trunions GPI rod-mod intake with I-M heat sheild Circle D 258mm Pro single disc 3700 rpm stall converter 169F thermostat & manual fan switch Tuned by Ryno at GPI - 455 RWHP / 416 lb-ft |
12-31-2019, 05:27 PM | #14 |
Yep just had to notch mine out so belly pan fit flush with bottom of the car. Thats crazy how you didn't need to do the same thing hmm?
FBO. Cammed. Flex fuel.801whp/741wtq on e85
