02-21-2020, 12:19 PM | #1 |
Previously CS10SS
Drives: 2017 ZL1 A10 Join Date: Jan 2017
Road Tires for 20" Rear Wheels : 715 RWHP
Looking for some input on the best tires for 20" Rear Wheels. Not for Straight Line Drag Racing at the track but instead day to day driving on roads and highways. Specifically for being able to accelerate through corners (getting on/off highway ramps).
I have tried: NITTO NT555 G2 Tires.... don't grip well enough MT ET Street S/S.... grip well in a straight line.... not so much through corners + that wobble. I was planning on trying the Toyo R888R's next but they seem close to the MT's? Am I wrong? Any input is welcome.
'02 Trans AM - sold
'05 SRT4 - sold '05 STI - sold '96 300ZX - sold '10 2SS/RS M6 455rwhp - sold '13 ZL1 M6 720rwhp - sold '17 ZL1 A10 930rwhp - Katech Built |
02-21-2020, 12:49 PM | #2 |
Instagram: Sangstah
Pilot Sport 4s is probably your next best bet for a street tire. When you step up to a Toyo R888R or Michelin Pilot Cup 2 or M/T ET Street radial similar soft 100 tread wear tire, the grip will be amazing but the tire life will be short.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
02-21-2020, 02:53 PM | #3 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
4s is going to be my next set in a couple of weeks. A friend at work has them on a Mustang, and I've been impressed with them on his car
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp // CSP LT's & Ultra Cats // Elite Ultra CC // BMR MM
Past Rides- 2014 ZL1 M6 Red Hot | Tons of mods 2004 CTS-V M6 Silver | Many mods 1995 Corvette M6 Torch Red | A few more mods 1992 Camaro M5 White | A few mods |
02-21-2020, 04:26 PM | #4 |
Previously CS10SS
Thanks. Not so much worried about the life of the tire.... just kinda the way it goes with owning a performance car.
More concerned with the "softness" while executing high speed turns on the highway. Would the R888Rs or pilot cup 2's be a little more firm or are they just as soft as MT's?
'02 Trans AM - sold
02-21-2020, 04:53 PM | #5 |
Drives: 2013 zl1 vert Join Date: Dec 2018
nitto nt05
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
02-24-2020, 11:37 AM | #6 |
709 RWHP & 677 RWTQ
Drives: 13' HPE 800 ZL1..... IOM vert, M6 Join Date: Feb 2013
R888r's are amazing. Good straight line grip,Not as grippy as MT's but close, good cornering. Will wear quicker than pilot's.
11.34 @ 124.88
02-28-2020, 01:08 PM | #7 |
Drives: 2012 ZL1 Join Date: May 2017
I had the Pilots on my C6 and much prefer the R888R's. Much better grip all around.
02-28-2020, 03:13 PM | #8 |
Chevy Enthusiast.
Drives: 2015 Camaro ZL1 Summit White Join Date: Jan 2019
Any reason that the BFGoodrich G-FORCE COMP-2 A/S are not being considered?
Levon H. Bone Stock |
02-29-2020, 07:08 AM | #9 |
Drives: 2013 ZL1 Camaro Join Date: Feb 2018
The tires being discussed are summer tires, worthless below 40 degrees. Great for track or aggressive street use. BFG is an all season tire, acceptable street performance that last a lot longer.
04-14-2020, 03:53 PM | #10 |
Drives: ZL1 Join Date: Dec 2016
For the type driving you are talking the Goodyears that come on the ZL1 are calling your name to get them.
04-14-2020, 04:12 PM | #11 |
fo'shizZL1
I can attest that for street driving, the Pilot 4s tires are awesome, now that I've had them for a month or so. They grip really well, without needing to heat them up as much as the stock GY tires.
