04-02-2020, 07:48 AM | #1 |
Drives: 2012SS Join Date: Aug 2018
LSX376-B15 or TMS 370/408 fully forged?
I blew up my engine and I need a new one now.
Which one one would you choose (B15 is ~2k cheaper)? I am planning to run it with a base AGP TT kit and stock driveline to make 600-650whp until I upgrade my driveline and fueling. After that I might shoot for 800-1000whp. One of my concerns is that 408 will produce too much power for my clutch and tranny to survive even with weakest 4.5lbs springs. Will it? LSX376-B15 specs: Part Number: 19299306 Engine Type: LSX-Series G en IV Small-Block V-8 Displacement (cu in): 376 cu in (6.2L) Bore x Stroke (in): 4.065 x 3.622 (103.25 x 92 mm) Block (P/N 19260095): LSX cast-iron with 6-bolt, cross-bolted main caps Crankshaft (P/N 12603616): Forged 4340 steel Connecting Rods (P/N 12607475): Forged powdered metal Pistons (P/N 19259381): Forged aluminum Camshaft Type (P/N 12638426): Hydraulic roller Valve Lift (in): 0.560" intake / 0.555" exhaust Camshaft Duration (@0.050 in): 210° intake / 230° exhaust Cylinder Heads (P/N 19201805): LSX-LS3 rectangular port; with “as cast” 68cc chambers and 6-bolt attachment Valve Size (in): 2.160 intake / 1.550 exhaust Compression ratio: 9:1 Rocker Arms (P/N 12569167 int): Investment-cast, roll trunnion Rocker Arms (P/N 10214664 exh): Investment-cast, roll trunnion Rocker Arm Ratio: 1.7:1 Recommended Fuel: 87 octane Maximum Recommended RPM: 6,600 Reluctor Wheel: 58X Balanced: Internal TMS 370/408 fully forged specs: Blueprinted GM block Seasoned core
ACL coated racing main bearings ACL coated racing rod bearings Thompson Motorsports single piece racing cam bearings K1 forged crankshaft with reluctor 3.622" or 4.000" Manley H-Heavy 4340 forged connecting rods with ARP 2000 rod bolts You choice of Diamond or Wiseco shelf piston with GFX file fit rings Steel ring set Frankenstein Thompson Motorsports edition M311 heads 11* CNC ported aftermarket casting 6 bolt heads Extreme duty stainless intake and extreme duty solid exhaust valves Billet Rocker Rails .660" platnum springs Thompson Motorsports custom ground Camshaft Thompson Motorsports custom length Chromoly pushrods Stock replacement bolts ARP HEAD STUDS ADD $366 OR $400 FOR 6 BOLT Melling Select High pressure oil pump Billet adjustable timing set Thompson Motorsports high RPM lifter set Trunion Upgraded Rockers GM MLS head gaskets GM lifter trays Thompson motorsports Professional assembly and 12 month unlimited mileage warranty
2012 2ss A6, AGP TT kit, 54/57 BallB, AUS 1400cc injectors, Meth, 1LE suspension, HRE FF01 20x9" front, 20x10.5 rear.
04-02-2020, 08:31 AM | #2 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
I don't know enough to give you an opinion on which engine. As fars as what your driveline will hold it depends on what you are doing. Stock will hold up to 800-1000whp on the street as you will spin. Go to the track with stickies and you can break stuff at 500whp and it gets easier the more hp and harder launch you go with. Eliminate wheel hop and preload the driveline before launch helps. Shock, and wheel hop kill things.
04-02-2020, 08:42 AM | #3 |
Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
No dog in the fight, for I’m in the same boat as searching for a short block for my FI build. I did see TMS with a 408 w/ rotating assembly for sale for 4250$. Plus your heads are what 2500$-ish. Idk if it’s going on still, but I emailed them yesterday. That warranty is always nice..
Too much power... lol |
04-02-2020, 09:18 AM | #4 |
I would say, save your money on heads stock ones are good and cost/hp is really high on aftermarket, FI really doesn't need heads until you're for a lot more than 1khp
04-02-2020, 09:26 AM | #5 |
I am not sure my heads and cam are still alive and I would not trust local shops to check, repair and assemble everything back because they have very little experience with Camaros :( They are also willing to ask about 1k for assembly.
So I think I need a complete long block. Maybe I could ask TSP to put cheaper ls3 heads, those would be 1k cheaper.
04-02-2020, 09:27 AM | #6 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
I have a LSX376 B-8 and make 757 rwhp through a PD blower and 4L80e. Using accepted ratios, that's close to 900 hp at the crank. No issues for years.
If you are planning on going TT, save some money and get the B-8. |
04-02-2020, 09:28 AM | #7 |
Served USN - Atomic Chimp
Drives: 2021 Camaro ZL1 1LE A10 (stock) Join Date: Jul 2012
TMS. Iron block for sure as you're likely to keep wanting to bump the power more, then more. Fuel systems definitely first choice to improve over heads. Driveline is essential to be able to put the power down without breaking stuff. Or, just power-up and you'll be replacing those items one-by-one as they get shredded.
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
04-02-2020, 09:43 AM | #8 | |
Isn't it closer to 1000 because the blower takes some power to spin itself? 900x0.85 = 765, so it's only for the tranny losses accounted. I've been thinking of B8 but from what I read here and other forums it wouldn't hold more than 14psi and it starts pushing water at that boost level.
04-02-2020, 09:48 AM | #9 | |
04-02-2020, 10:48 AM | #10 |
Drives: 2010 IOM 2ss/RS Join Date: Sep 2009
not sure on the engine, but my trans is fully blown out, never been on the track, no stickies...just 700rwhp...wasnt much good left in the trans.
Turbonetics running 8lbs boost at 700rwhp tuned by Hi Rev, installed by K&M w/cat-muffler delete, ACS splitter, Fesler GFX, MPD1 spoiler, Custom painted Rally stripes, Cordon CR1 wheels 275/315s, Hotchkiss comp sways and end links, Barton shifter
04-02-2020, 12:18 PM | #11 |
Drives: 2011 Camaro SS, LSX, 4L80E Join Date: Nov 2018
I started with an LSX B-8, overtuned it, bent a rod, rebuilt it as a forged 409. As it fried things, I replaced the tranny, rear end, pumps, injectors, E-85, pulleys, on...and on... and very soon a new Kong blower.
I never planned on getting in this deep. It's an addiction. You’ll want more. If I ever do this again, I realize that now. Just go all in on whatever component you’re doing. B-15 won’t be enough. Build it while it’s out of the car and make it cheaper by doing it right the first time. If that means you have to wait longer for the finances on the next mod, so be it. You don’t want to half step the next mod either. May seem like it costs more and takes longer going all in, but that’s cheaper and faster than going half in on everything, then replacing it all in later. And building it solid enough not to break is the cheaper option than over tuning a lesser set up. That’s just my opinion, based on how I am, and from what I see, how many others are as well. But maybe you can stop with lower power. If you want an LSX, you’ll probably be eventually going all in. Be honest with yourself, and make the decision that best suits you, whatever that may be. |
04-02-2020, 01:21 PM | #12 | |
up
04-02-2020, 01:45 PM | #13 | |
04-02-2020, 03:45 PM | #14 |
Drives: 2010 2SS LS3, 2013 duramax Join Date: Nov 2012
There is a lot more to it than just boost pressure.
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
