![]() Drives: 1969 RS/SS 2010 SS/RS Join Date: Aug 2009
SS Grille Emblem Removal ?
How do you remove the red ss emblem from the grille? I have removed the bowtie and made a new holder for the trailblazer ss emblems and don't want the red ss emblem on in the grille with the new one installed.
#2 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: RSSS Join Date: Dec 2009
I am curious about this as well. I was going to look into it when I went home for the holidays.
Just found this digging around some other threads. Thanks to Mr Smith: Quote:
Onechuck
Drives: 2010 Camaro IBM 2SS\RS SC & Cammed Join Date: May 2009
There is a little plastic tab that is a part of the front grill so whatever you do don't just pull on the SS emblem because you will break it. The SS emblem is held on with double sided tape. Get you some fishing line and run it behind the emblem carefully and it will come right off. Then just clean the little tab up and you are good to go.
2G1FB1EV7A9100028
Drives: 2010 Jeep Wrangler Hemi Join Date: Mar 2009
It's actually pretty hard, and a pain to get back into place. There's tabs on the back (hard to get to and hard to remove) you can use a flat head screw driver on the right side and push it in with your finger from the left, I'd suggest doing the left first.
# 28 - Victory Red 1LT/RS (SOLD)
The Demon Photographer
![]() 1SS IOM LS3, GM 4-pack guages, SLP SS Front Emblem, Roto-Fab CAI, Solo Performance Mach X Exhaust, Barton Industries Short Throw Shifter |
#6 |
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova Join Date: Oct 2008
Is this the pics you want
#7 |
Remembering those in Blue
Drives: 2010 Camaro 2SS Blk w/IOM Int Join Date: Sep 2009
2SS,
Where did you get the SS from- Love it. Gotta have it. Mike
#8 |
#9 | |
Thanks, Mike
#10 |
Yes SR.
There are 2 parts there first is the SLP filler part for your grill, part #100032A it like $35. Next is the SS emblem the same one as on the rear Its from your GM dealer, This is the Part # 15211285 and i paid $15 per. Last edited by 2SSRS@Gen5diy; 01-01-2010 at 04:41 AM. Reason: Had the # for the part |
#11 |
2SSRS,
Thanks, my brother! Mike
#12 |
2SSRS,
After looking at SLP performance- There are two Part numbers for the filler One is 100032A, the other is 100033A the PN 100042A that you provided is the old school SS emblem. Do you know what one of the fillers you used? Thanks, Mike
#13 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
It looks great and should have come this way from the factory!
#14 | |
The Right part # for the SLP is # 100032A |
| SS vs Z. Why?? Not another Z28 Thread!! Just curious. | TRIXXTERR | General Automotive + Other Cars Discussion | 29 | 01-21-2011 10:27 AM |
| SS ENGINE COVER EMBLEM & NAMEPLATE 2010 CAMARO | Kirban Performance | V8 Bolt-Ons & Tunes | 0 | 11-30-2009 02:40 PM |
| Camaro SS manual shipment (not production) hold officially confirmed by GM (UPDATED) | Tran | 5th Gen Camaro SS LS LT General Discussions | 715 | 07-24-2009 12:05 AM |
| Camaro LS / LT / RS / SS specs and options! | CamaroScotty | 5th Gen Camaro SS LS LT General Discussions | 119 | 09-02-2008 10:46 PM |
