06-04-2020, 09:07 AM | #1 | |
Drives: 2019 Red Hot ZL1 1LE: 2012 RAM 2500 Join Date: Mar 2012
Front end noise
Maybe someone knows what might be causing this, it started a few days ago and I have less than 1K on the odometer, it's coming from the Right Front and this occurs driving around for a while.
06-04-2020, 10:05 AM | #2 |
Drives: 2018 2SS 1LE Black Join Date: Aug 2018
Sounds like some crappy country music. Check your lug nut torque, should be 140 lbft, I had mine clunking when turning slow speed and that was it.
06-04-2020, 10:29 AM | #3 |
Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
I thought the music sounded good.
But I agree that lug nut torque would be my first check. In fact, I would jack up each wheel off the ground, loosen all lugnuts for that wheel and ensure the wheel is seated properly on the hub, and then torque to 140 lb/ft. |
06-04-2020, 11:28 AM | #4 |
No need to bag on what I listen too thank you very much....lol, I always make sure the lug nuts are at 140 foot pounds and the wheels are seated properly, sounds like something is hitting the spring, I even checked out everything and no visible damage and nothing looks out of place. I can always put the stock wheels back on and see what it does, right now I have the APEX ARC-8's on.
06-04-2020, 01:56 PM | #5 |
1LE Convert
Drives: 2018 ZLE Join Date: Apr 2017
Are you using aftermarket wheels? This happens to me also when I run 18" wheels. The wheel weights on the inside of the front wheels rub my brake ducts when I have a lot of steering lock.
Even if using stock wheels, suggest you crank the wheel all the way and visually inspect the wheel clearance to stuff in the wheel well while the car sits still.
2016 Porsche 911 GTS (Racing Yellow)
2002 BMW Spec E46 race car (Lizard Green) Previous cars: - 2018 Camaro ZL1 1LE (Red Hot) - 2018 Miata RF GT (Machine Gray/Auburn) - 2017 Camaro 1SS 1LE (Summit White) - 2008 BMW 135i (Montego Blue) - 1996 BMW 328i (Arctic Silver) |
06-04-2020, 04:52 PM | #6 |
I have APEX ARC-8's 19x10 et20 and I have checked for rubbing and nothing is rubbing, from a sit still I can move the steering wheel to the left and right 9 to 3 motion and I get that sound, I will put the stock set back on and see what it does.
06-04-2020, 11:18 PM | #7 |
Drives: 18 ZL1 - M6 Join Date: Mar 2019
Does it only happen when backing up?
06-04-2020, 11:46 PM | #8 |
Drives: 2018 ZLE (M6/hyper blue) Join Date: Nov 2015
06-05-2020, 07:16 AM | #9 |
It does it when backing in and it also did it when I was making a turn on to my road, it's more pronounced when backing in and of course when I am parked in my carport when I turn the wheel back and forth.
06-05-2020, 07:54 AM | #10 |
2018 ZL1 1LE
Drives: 2018 ZL1 1LE Join Date: Aug 2017
Have you checked the sway bar end links, the nut is known to get loose.
06-05-2020, 07:56 AM | #11 |
Drives: 2018 Mosaic Black Metallic ZL1 A10 Join Date: Sep 2017
