Old 06-07-2020, 03:38 PM   #1
lewylew
lewylew's Avatar
Drives: 2010 ZL550& 2021 C8 Z51
Rear coilover denting trunk HELP
Has anybody seen this issue. I looked in my trunk to and notice that above both coilovers there have been repeated dents/bulges. Was running Pedders switch a little while back to KW V3.
lewylew is offline   Reply With Quote
Old 06-07-2020, 03:43 PM   #2
Omega
Drives: G8
Did the shock blow out the rubber isolator in the top hat?
Sent from my Pixel 4 XL using Tapatalk
Omega is offline   Reply With Quote
Old 06-07-2020, 03:45 PM   #3
lewylew
lewylew's Avatar
Not sure it would have had to happen to both sides. Think I still have my old Pedders I will have to pull them out and look
Old 06-10-2020, 12:49 PM   #4
lewylew
lewylew's Avatar
I think when I had my pedders installed shop most have done this for clearence for some reason. Don't understand why. This is why I try to do most of my own work. Shouldn't have been lazy.
Old 06-10-2020, 02:24 PM   #5
RankSS
Drives: 2010 Camaro SS
Weak minds and big hammers are a bad combination.
2010 Camaro SS RS, Maggie with 3.4" pulley, 60# injectors, ADM dual fuel pumps, ADM Stage 2 Cam with Brian Tooley springs and pushrods, black CAI intake, Stainless Works long tube headers w/gutted cats, ZL1 Diff w/offset bushings, Pfadt lowering springs, Pfadt sway bars, Pfadt solid sub frame mounts, BMR trailing arms and toe rods, Hurst short throw shifter, Painted on Hugger Orange stripes, Forgestar F14 Piano Black wheels, Nitto NT05 rubber.
RankSS is offline   Reply With Quote
Old 06-20-2020, 05:59 PM   #6
mikeman
Banned
Drives: 2015 Camaro
If the hammer is big enough, it can fix almost anything I believe.
mikeman is offline   Reply With Quote
Old 06-20-2020, 06:22 PM   #7
lewylew
lewylew's Avatar
think you guys may be right. old pedders are fine. have car at suspension shop have them cutting it out and adding a plate so i can make easy adjustments.
Old 06-20-2020, 06:23 PM   #8
lewylew
lewylew's Avatar
idiots worked on my car early on
Old 06-20-2020, 06:44 PM   #9
Avenging Orange
Avenging Orange's Avatar
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
