06-14-2020, 07:26 PM | #1 |
Drives: 2015 black Z/28 Join Date: Nov 2015
Small groove in CCB rotor
Hi All -
I've developed a small groove in my front left rotor. Am soon taking it in to have it checked out, but wonder if anyone else has seen anything like this? Pads appear to be in good shape. It could something lodged between pad and rotor, but that's hard to fathom. Appreciate your insights. -John
06-15-2020, 07:36 AM | #2 |
Drives: 2010 2SS/RS Join Date: Dec 2009
I’d say if you can’t feel it with your finger nail you should be good to go.
Orange Krush II
06-15-2020, 08:24 AM | #3 |
Thanks. It's very shallow and I can barely feel with my finger nail. Really odd. No clue what's causing it.
06-15-2020, 08:40 AM | #4 | |
Drives: '10 Camaro SS,Jeep Commander Hemi Join Date: Mar 2010
line on rotor
I would say there was a small stone pebble,for a short time between your rotor & pad,it only lasted a few rotations then was pulverized and ended up as dust,It doesn't look serious,Rotor certainly can be turned,I'd do both rotors to keep the braking balanced. Happy cruising ! |
06-15-2020, 09:53 AM | #5 | |
06-15-2020, 11:37 AM | #6 | |
carbon fiber Rotor
You're correct,I forgot it was a carbon fiber rotor,my bad! |
06-15-2020, 02:15 PM | #7 |
You can't turn slotted and/or drilled rotors regardless of what they're made of.
06-15-2020, 02:29 PM | #8 |
06-15-2020, 03:42 PM | #9 |
Thanks, all! Am not overly worried and do not track it Will keep an eye on it.
06-15-2020, 03:44 PM | #10 |
Jumanji
Drives: '14 Z/28 - AGM - No A/C Join Date: Mar 2014
Well, it can only get better from here.
Keeper of the 5th Gen Z/28 Registry.
Registry Facebook. Follow: @5th_gen_z28_registry I track wrecked Z/28s Total lost -41 |
