07-14-2020, 02:26 PM | #1 |
Drives: 2018 SS 1LE Join Date: Oct 2017
Dead battery 18 ZL1LE
When not in use, I keep it on a maintainer. If the car sits without maintainer for a week or longer the battery is dead. Replaced it with an optima yellow top yesterday. Are dead batteries common ?
2018 ZL1 1LE
1966 Corvette 427/425 vert 1969 Corvette 350/350 |
07-14-2020, 02:57 PM | #2 |
Drives: 2016 1ss camaro Join Date: Feb 2016
mine is a 2016 ss and mine died last spring so less than 3 years
07-14-2020, 03:35 PM | #3 |
I tested it at autozone and they stated it was head. Yet at home shows 12.7 volts. Is there more to the battery?
2018 ZL1 1LE
07-14-2020, 05:25 PM | #4 |
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
Mine sits for 2 weeks or more at a time before I drive it. Never had any issues with the battery. Though I do drive it every day for about 2 weeks before letting it sit for another 2 weeks.
2018 with 17k miles. How much do you drive it once you do get to drive it? I would think a good trickle charger would keep the battery maintained. |
07-14-2020, 05:52 PM | #5 |
Drives: 2019 SS Join Date: Apr 2020
It's not volts that starts a car, it's amperage, you can have a battery with 12.7 volts but wont start the car due to no/low amperage. Test machines put a draw on the battery for amp draw.
07-14-2020, 05:58 PM | #6 |
Drives: 2018 ZL-1 Join Date: Jan 2018
Bad batteries can show good voltage just sitting, but under load they fail to deliver the juice. A good trickle charger / maintainer can keep a battery alive for many years. Mine is plugged in every time I park the car, because I only drive it a few times a month.
07-15-2020, 10:59 AM | #7 |
Drives: 2015 Z/28 #397 2022 ZL1 #1799 Join Date: Jul 2009
Lead acid batteries want to live at a high state of charge, 13.4V or so and you’ll be set. Get a good maintainer a leave it connected when not driving. There are some fairly decent “ battery testers” on Amazon that are “same same” as the Midtronics EXP-1000. That’s a ~2k tool that kicks ass but the $50 Amazon one will do a CCA test and let you know “ good or bad” battery. They do a quick pulse to see if it can deliver the 600 or so CCA rating. I’ve tested the Amazon tool against the Midtronics and the results are the “same” and the numbers close enough.
07-15-2020, 11:17 AM | #8 |
Drives: 2019 ZL1 Riverside Join Date: Apr 2020
https://www.amazon.com/OptiMATE-Ampm.../dp/B003UANXCE
The best auto charger on the market These cars eat batteries. Turning over a 6.2L takes some juice |
07-15-2020, 11:35 AM | #9 |
Drives: 2019 ZL-1, Shadow Gray, Sold Join Date: Jan 2019
Mine sits on a charger anytime it is in the garage. Only takes a minute to take it off and the hood being open is a "good" remainder that it is on there, LOL!
07-15-2020, 12:39 PM | #10 |
All the replies are greatly appreciated.
2018 ZL1 1LE
07-15-2020, 08:34 PM | #11 | |
Drives: 2015 Camaro Z/28 Join Date: May 2019
07-16-2020, 02:54 PM | #12 | |
Drives: 2018 Chevrolet Camaro ZL1 Join Date: Jun 2018
Unfortunately, ACDelco batteries failing within a few years is certainly not uncommon. |
07-17-2020, 07:38 AM | #13 |
Drives: 2019 ZL-1 Join Date: Feb 2009
Get a Batteryminder tender they have a desulfurator mode and will often bring a battery back. Brought mine from 60 % to 90 %.
2019 ZL-1 Acquired 4/23/21 at 6300 miles. Riverside Blue, A10, PDR. Traded in 2017 2SS with 6M and 32k miles. Continental Extreme Contact Sports. Now has 10,000 miles...
2012 Yukon XL Denali w/ 6.2 AWD |
07-17-2020, 09:12 AM | #14 |
