07-20-2020, 06:42 PM | #1 |
Drives: 2014 Chevy Camaro 1LT RS Join Date: Apr 2020
Service Stabilitrak. PLEASE HELP
2014 Camaro 1LT w/RS
80,466 miles at time of posting. It's been running perfectly up until this morning when suddenly the Service Stabilitrak message pops up on the HUD. ABS, Traction Control, and a few other lights kicked on. Photo attached. From everything I've found online I can't make a solid idea on what might be wrong as this all started all of a sudden this morning. Below is a list of what I know for certain. .Cruise Control still works fine. .No weird smells or sounds. .Key kept getting stuck in ignition this morning, would only come out after waiting several minutes and power cycling the car. However, since leaving work that hasn't been a problem. .Seems to be running fine at idle and shifting fine. .Only mods to the car are cosmetic. Louvers on the windows and the 6th gen ZL1 conversion bumper from IKON. .About a month ago the front, driver's side fender liner broke out. Just got the replacement but it hasn't been installed yet which makes me think the dirt and debris could've jacked with wheel speed sensors but I'm not a professional so idk. .Brake lights still work .Went and got it scanned at AutoZone, not a single code. Came back clean. I'm at a loss. I'm so confused on what is causing this. Any help would be greatly appreciated bc im not one to let dash lights sit. Sent from my SM-G988U using Tapatalk |
07-20-2020, 07:13 PM | #2 |
Drives: Never just fly under the radar Join Date: Jul 2015
I'd start with a battery maybe. These things are notorious for giving all kinds of trouble when the battery starts to fade. Even if it has plenty of juice to start the car. GL
Old Skool |
07-21-2020, 08:27 AM | #3 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
I don't think Autozone scans for anything beyond ECM codes. The Stabilitrak can be set by other modules. It needs to be scanned by a tool that can read the other modules.
07-21-2020, 09:10 AM | #4 |
Drives: 13 ZL1 Join Date: Jun 2017
Check battery
07-21-2020, 01:38 PM | #5 |
Drives: 2010 2SS/RS A6 Join Date: May 2019
Battery or battery cables.
07-21-2020, 05:14 PM | #6 |
Drives: 2012 Camaro SS Transformer Join Date: Sep 2013
Its been a while but I think I had similar indications when my battery got to be about 6 years old. Even though the car started I replaced it. I never checked voltage on battery just figured it was old enough to replace. Fixed warnings.
Mods: trunk subwoofer and amp, LED lighting (fogs, interior, trunk), skip shift eliminator, CAI cold air kit, Vmax ported throttle body, Stainless Works retro chambered cat back, JBA Cat4ward SS ceramic coated headers Potential Next Mods: Tune, F&R sway bars, rear cradle bushing inserts and trailing arms |
08-19-2020, 06:50 AM | #7 |
Drives: 2016 Chevy Camaro Join Date: Jul 2020
Curious...when your Stabilitrak and TCS lights came on, did you also get the service power steering indicator? And was it just lights and indicators, or did your steering wheel start acting as if there was an issue with your power steering?
08-20-2020, 06:36 AM | #8 |
Drives: 2013 camaro SS Join Date: Aug 2019
keep us updated
08-20-2020, 10:23 AM | #9 |
376 cubic inches of fun
Get a new battery.
If you have the origin from 2014, don't even bother testing it. Just get it replaced. |
11-06-2020, 11:03 AM | #10 |
Drives: 2024Camaro 2SS CE Convertible Join Date: Jul 2013
Maybe related, maybe not. I just replaced the battery. Twice, while driving down the road I get the “service stabilitrak” and a flashing check engine light and nothing else. And then it’s gone. No other indicators and no limp mode. What do you think?
