09-05-2020, 11:36 PM | #1 |
Drives: 1SS Summit White 6 speed Join Date: Jul 2017
LT1 fuel system guys: how far are you comfortably pushing boost?
Had an awesome time driving in North Georgia mountains today. Car felt amazing with the 888r's on the back.
Thinking of getting smaller pulley for the Magnuson. Thinking someone needs to talk me out of it.
16 1SS M6 White
Magnuson 2.3 Heartbeat Roto Fab Solo Performance Cat deletes and Axleback Hurst short shifter #'s coming soon Riaction coilovers 1LE sway bars BMR mm BMR chassis brace Flow one 19" wheels wrapped in Mickey Thompsons 02 Z28 M6 35th anniversary 80k miles T-tops Leather Bolt ons Joy to drive this classic every day! Daily Driver |
09-06-2020, 07:01 AM | #2 |
Drives: 2017 Camaro 2SS A8 Join Date: Aug 2018
If you’re still on the stock LT1 fuel system, maybe another 30-40 horse safely I’d guess (your sig says you’re at 551 now). Start upgrading that fuel system if you want to play with boost...
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors, LPE BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.48@150
09-06-2020, 08:04 AM | #3 |
Drives: 2022 Lt1 A10 Join Date: Nov 2015
I'd say 600 will be your limit. Are you running the 90mm pulley?
2022 Lt1 6.2 A10, Maggie 2300, THPSI Port Inj/10 rib, Rotofab, E, Nickey, SCOL, Griptech, RC Bandits, Hoosiers/MT 9.80@142.96 1.44 60ft, 6.34@112 707/669 RWHP/TRQ. 16SS Maggie 2650 9.41@147 1.35 60ft, 5.99@119. 16 C7 A8 10.90@128 Bolt on stuff
09-06-2020, 01:25 PM | #4 | |
I'm still on the 98mm...lots of opinions about fuel limits, heat soak, etc have swayed me away from going smaller. I think people have learned alot more about the platform now than when I got the kit almost 3 years ago
16 1SS M6 White
09-06-2020, 02:36 PM | #5 |
Drives: 2017 1ss 1le Join Date: Sep 2015
i'd more worried about the pistons then the fueling
09-06-2020, 04:29 PM | #6 |
Get the fueling right, and the pistons magically get stronger... I was over 650 wheel last year on stock pistons and rods with no problem.
09-06-2020, 07:03 PM | #7 | |
Drives: 2015 C7 Z06 M7 Join Date: Dec 2012
We've run at 728 RWHP all summer (10.3s @ 135) with straight E85. We'll be bumping the boost up a bit more for our next track outing to drop into the single digits. Will that be the limit? Maybe - we'll let you know. |
09-06-2020, 10:19 PM | #8 |
Ok thanks alot guys
Good to hear other's experiences My car still puts a smile in my face everytime I drive it. Can't imagine not having boost now. Lol
16 1SS M6 White
09-07-2020, 08:53 AM | #9 |
Drives: 2016 1SS NFG A8 Join Date: Aug 2017
I would leave the boost alone, upgrade the fuel system, flex sensor, and run a mix of E for added octane and cooling. You will make more "safe" power then upping the boost with the stock fuel system on 93. I bet you would hit around 600whp with E60. 93 pump isn't really enough octane for these high compression engines unless we are talking very low boost levels(5-7psi tops) which is why many are pinching the rings. Yes they have tight ring gaps but if the compression was a point lower like the LT4 they would tolerate a lot more power on 93 and likely be less failures.
2016 NFG 1SS A8
Options-2SS Leather/NPP Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA |
09-07-2020, 06:32 PM | #10 |
Drives: 2018 2SS Camaro Join Date: Mar 2020
I'm at 9.5psi, apparently a relatively conservative tune, about 560whp. In a year of driving Ive had no issues, although I dont drive it hard too often either and rarely get anywhere near redline ....
09-07-2020, 08:54 PM | #11 | |
I would upgrade the Cam also. It just seems when you get close to 600whp it is exponentially more expensive to push past it than to just let it be at a "safe" level based on what kind of octane is available. Aftermarket is still atrociously expensive for alot of parts on 6th gens
16 1SS M6 White
09-08-2020, 09:01 AM | #12 |
I think the fuel system is a good route. Probably around 2000.00 with labor. Its a pretty easy job on a 2300 Maggie. Injectors are not plentiful at this time and hard to get unless something has changed in the last week or so.
09-08-2020, 09:30 AM | #13 | |
I think the best approach is to invest in the fuel system first, then build the motor second depending on goals. These engines will tolerate some pretty good power if you keep the cylinders cool.
2016 NFG 1SS A8
09-08-2020, 08:33 PM | #14 | |
Drives: 17' 1SS 1LE GBA-Black Join Date: Mar 2017
Would the upgrade to the LT4 fueling safeguard the pistons from heating too much (and then potentially causing the rings to butt)? |
