10-15-2020, 01:23 PM | #1 |
Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
Backhalf 5th gen
Thought I'd post up the new wheels. Currently have 15x14s on the car and they stick so far under it was time to fill the rest of the tub out with these 16x16s.
Current tire is a 32x14.5w Going with a 33x17x16 Will gain 4" of tread on the ground total. In the pic you can see how much more room i have for tire
10-15-2020, 08:09 PM | #2 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
Nice- Wheels up!l
10-16-2020, 10:17 AM | #3 |
I have never seen a reference pic with a hand on a drag wheel like that....WOW!!!
SOLD: 2010 2SS/RS L99-A6 K&N CAI, Speed Engineering Long Tube Headers, Stainless Works hi-flow cats, Flowmaster American Thunder Cat-back. Tuned by Corvettes of Westchester. 1/LE rear suspension conversion, Bilstein B6 Stuts/shocks.
10-16-2020, 01:38 PM | #4 |
That's freakin amazing ! Gonna look great for sure, and with more rubber, should be hookin great !!
10-16-2020, 02:03 PM | #5 | ||
I'll throw a pic of of the 2 wheels side by side when I get tires mounted
10-16-2020, 06:52 PM | #6 |
Drives: 13' 1LE Join Date: Apr 2012
woah!! Nice racecar!
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
10-16-2020, 08:43 PM | #7 |
Drives: 2013 1SS 1LE Join Date: Jun 2016
You need a big cowl hood for that beast
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq. |
10-16-2020, 09:15 PM | #8 |
Thank you!
Yes sir! Its on the list! A 5" cowl would take some trimming even unfortunately
10-17-2020, 09:57 AM | #9 |
Very nice race car for sure! And yea a big cowl hood would look awesome! Of course I'm a bit biased. lol.
10-17-2020, 02:46 PM | #10 |
Drives: 2010 SS L99 Join Date: Sep 2018
With as much as you've carved that thing up, if you posted tomorrow you were converting it to a mid-engine setup I wouldn't be surprised lol. This has been a very interesting build! Following along as always
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 |
10-17-2020, 03:09 PM | #11 | |
Thanks buddy! This is the last go round with this thing. Ill be happy when I get that 4 second slip next season
11-19-2020, 04:29 PM | #12 |
Finally got the tires mounted. Side by side with old for reference
11-20-2020, 05:45 AM | #13 |
2&THEHIT
Sweet. Fills the well up nicely!!
11-20-2020, 10:43 AM | #14 |
Wow bro, that looks soooo much better!! Gonna hook better too with the extra tire on the ground... Very nice. Good luck...
