10-30-2020, 03:28 PM | #1 |
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
UNDERSTEER AND THE 305/35/20
I NEVER TRACK MY 1LE, and it's time to buy a new set of tires. I have settled on the Firestone fire hawk indy 500's . I was planning on running the 305/35/20's in the rear and the 285/35/20's in the front . Will I notice any difference ? Will it understeer a lot when pushed on the street ? Am I gaining anything by using the 305's in the rear and 285's in the front ? Will I loose anything running this set up ? Should I just go with the 285's all the way around and stop being necrotic about it .? One thing I can tell you is the stock Goodyears really suck bad in the rain .
OLD GUY FLYING FAST AND LOW
10-30-2020, 03:30 PM | #2 |
Tri-County Camaro SWFL
Like you never tracked your car I've never ran 305s in the rear..... having done a few autocross outings i must say I dont see why anyone that cares about the handling of this car would purposely induce more understeer. If you are strictly a drag racer then year go for it. If you like pushing the car and like the way it handles then don't.
At the limit this car turns into a snowplow. I was one of those "purists" where I would never touch the balance of the car..... after doing the autocross I upgraded to a 32mm rear sway bar to dial out some understeer. I did go with MPSS after the goodyears were shot and now have the MP4S on. I couldn't do another set of G2s for daily driving. I do want to try the G3s now they come in our sizes.
10-30-2020, 03:43 PM | #3 | |
need a tire that's not terrible if it rains. The Firestones get a better overall rating than the stock goodyears and cost a good bit less . Im thinking the firestones are going to be a better tire on the street over all for me .
10-30-2020, 04:09 PM | #4 |
Drives: 2015 Camaro 2SS RS 1LE AGM Join Date: Oct 2013
I ran mine pretty hard at Tail of the Dragon and I like to push it on the streets too. I have 285s front and 305s on the rear with no issues at all with understeer.
Sent from my SM-G960U using Tapatalk
2015 2SS RS 1LE NPP/w Kooks headers, Procharged, ID1050X injectors, Katech belt tensioner, Mighty Mouse Catch Can, BMR subframe connectors, Matco driveshaft loop, AEM Wideband/Boost/Fuel gauges , Z/28 Splitter and Spoiler/w Wicker bill, Power Stop rotors and brake pads, MRR Z/28 Rep Wheels 20" w/p zeros 285 fronts and 305 rears, ZL1 addons Rock guards and Tow hook, Rear window louvers, Flags on the quarter windows and the moonroof, Billet aluminum door handles.
10-30-2020, 07:43 PM | #5 |
Drives: Black '13 2SS/RS/1LE w/NPP/NAV Join Date: Oct 2012
I've been running a 285/295 set up for a long time. I do have just about all of the old Justice Pete mods and run his alignment specs. When I first set up the car I started driving hard and my first hard right almost put me into the curb because it was that much improved.
That being said I'm switching to coil overs and I'm going to run 295/305. Also camber plates are mandatory to fit big tires up front. Sent from my SM-T837V using Tapatalk
My Build Thread... http://www.camaro5.com/forums/showthread.php?t=285054
10-30-2020, 09:59 PM | #6 |
not afraid of the wall
Drives: Camaros Join Date: Apr 2010
I beat mine on the street with 305’s in the rear, but I still oversteer simply because of my power level.
I am running Supercar 3’s which are great; however, downpours at highways speeds will cause hydroplaning, so you must adjust your speed accordingly when caught in that situation (i.e. drop down to like 55 in pouring rain that your wipers can’t even keep up with)
2023 1LE 1SS BCD GCF JF5 MN6 SIA SLN UQT
10/13/22: 1100 Past Camaros: 13 1LE|02 SS|01 Z28|00 SS|91 1LE|91 Z28|89 IROC-Z |
11-02-2020, 09:44 AM | #7 |
Drives: 1le Join Date: Nov 2015
I'm running 305/35/20 (Pilot Sport 4S) in the rear and notice and little more push in the turns but nothing significant. I don't autocross or road race at the moment so not a huge concern.
11-02-2020, 10:36 AM | #8 |
Looks like im going to order the Firestones in 305's for the rear and the 285's for the front. Hope they do better in the rain and I don't loose too much grip when the roads are dry . Going to be strictly a street driven car, no track days .
11-02-2020, 11:09 AM | #9 |
Drives: 2014 1le 1SS CRMT Join Date: Apr 2014
Ive been running 295/35/20 & 305/35/20 nitto 555g2’s love them .. But switching out my factory 20’s . For Vossen wheels . Im on the fence on 20’s or 21’s as i dont track my 1LE its mosty a weekend fun car show cruiser ! I’m thinking of going really aggressive!!
Maybe 10.5 or 11 fronts And 11’s or 12’s rear in either 20’s or 21’s Still up in the air Im on full BMR suspension with 32mm sway bar plus Pedders supercar coilovers I just love these Camaro 1LE ‘s |
11-14-2020, 10:23 AM | #10 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
Firestone 500s aren’t good for grip. But for the street probably ok. These cars will out handle safe speed limits as it is. When I ran 275/305 years ago with peddlers coil overs and bars, I had to put front bar soft with the big rear bar. And stiffen rear rebound to get rid of mist of the under steer. But on the street a bit under steer is good for safety.
11-14-2020, 01:16 PM | #11 |
Drives: 2014 1SS/1LE Join Date: Nov 2015
The Firestones are good street tires, hold their own in the rain, and don't turn into que balls when the temperature starts to drop. That said, they suck for autocross because they take a bit to warm up.
As far as balance goes, a square setup is the way to go, even with a stiffer bar in the back. Sent from my Pixel XL using Tapatalk
11-18-2020, 10:33 PM | #12 |
Drives: 2013 camaro 1le Join Date: Sep 2012
I’m also in the market for new tires and I like the look of 285 /305 set up . FYI Firestone indys are w rated 160 mph max our 1les came with Goodyear’s (y) rated over 186mph .
11-19-2020, 10:58 AM | #13 | |
speed rating on tires
11-19-2020, 12:39 PM | #14 |
Currently running Nitto Invos at 295/315.
I was going to run 295 square but sales guy at discount tire discovered the 315 was over 40 bucks less per tire then the 295 plus I do like the staggered look, so I went with it thinking the rears would be wearing faster then the fronts. After 6 track days, they have plenty of meat on them and they handle track abuse well as long as the pressures are set right. There is understeer but not as much as I was expecting and I can still rotate her with the throttle. I image with stickier DOT tires or slicks, there would be more understeer. Anyone running 305 square on the 1LE wheels? I heard you can squeeze 305s on the front 10.5 wheels without rubbing. |
