12-09-2020, 07:35 AM | #1 |
Drives: '12 Camaro 2SS/RS Vert Join Date: Oct 2020
Vararam VR-DRX or Rotofab CAI
The prices are about the same. Which one would be the better choice for performance. I have an LS3 M6 with a Solo axle-back. Future mods may include LT headers and tune and nothing much beyond that....
2012 Camaro SS Convertible: 2SS, LS3, M6, Triple Black. Mods: Solo Axleback, 1LE FE6 rear swaybar, CAGS delete, Vararam CAI, Heritage grill, Hotchkis springs, '15 FE4 struts/shocks, ZL1 side rockers, Velgen Classic5 wheels, Pedders radius rod bushings, ARH LTHs, gutted HFCs,...
12-09-2020, 08:09 AM | #2 |
Drives: 2012 Camaro SS Join Date: Dec 2019
Either one or the K&N system for half the price. All will perform pretty much the same function especially since you will be doing minimal modding.
I have had the K&N one on my car for the past year and I compared it to my friends rotofab and they are 90% identical and love the engine sound it gives.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
12-09-2020, 11:10 AM | #3 |
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
If you live in a hot climate , a sealed system than can only draw air from outside the engine compartment is what you want . Check out the tests posted here ,a couple years ago .
OLD GUY FLYING FAST AND LOW
12-09-2020, 11:28 AM | #4 |
Thanks gents good tips. Definitely opening up my options.
12-09-2020, 12:56 PM | #5 |
Systems that have the filter on the left side of the car Im a RotoFab fan.
12-09-2020, 01:27 PM | #6 |
Thanks. What do you mean by "filter on the left side of the car"?
12-09-2020, 02:10 PM | #7 |
Submarine Pilot
Drives: 2015 Commemorative Edition SS Join Date: Jul 2018
For performance, Vararam hands down.
2015 Commemorative Edition 2SS/RS [L99] -Black-
|GPI: Tune, Rod Mod, PTB; Vararam Intake; ARH 1_7/8 headers & 3" cat-back; GM 3.91 gears; Circle D 4c converter and trans rebuild; Derale trans cooler; B&M deep trans pan; JMS Pedalmax; Taylor Thundervolt 10.4 wires; NGK Ruthenium plugs; 160 tstat| |
12-09-2020, 02:57 PM | #8 |
12-09-2020, 03:34 PM | #9 |
Drives: 2013 Camaro SS Join Date: Feb 2017
For performance Vararam. For looks Rotofab.
2013 Camaro SS
Kooks Headers Vararam DRX 1le Differential 3.91 Bo White throttle body Magnaflow Competition Exhaust 12.391 112 MPH 10/05/19 |
12-09-2020, 04:31 PM | #10 |
From what is claimed, the VR-DRX performs on par with or better than the VR-SS (Over the Radiator version for 2010/2011 ). Whether or not that's true I have no idea, but I have heard great things about the DRX. Apparently fit and finish is also better than the OTR version.
The DRX replaces and integrates the OEM windshield washer bottle into the design which is supposed to help insulate from the hot engine bay and in their words, to 'direct flow into the scoop assembly'. It's a pretty cool design. I personally don't think the DRX looks as good as the Roto Fab or Z28 spoilers do, but I prefer function over style any day of the week. Some people like the OEM look of the DRX too. All that said, I really don't think you can go wrong with either one.
12-09-2020, 05:31 PM | #11 |
Gotcha. The DRX unlike the older version is on the left.
12-09-2020, 05:59 PM | #12 |
Drives: 2015 Camaro SS Join Date: Sep 2011
No other changes, I switched out the Roto Fab for the Vararam DRX on the same Dyno the Vararam made more fwiw.
2015 Camaro 2SS Cam/Heads/FBO 498/447 SAE |
12-10-2020, 09:54 AM | #13 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
I have Cold Air Inductions system. Top notch
12-10-2020, 11:16 AM | #14 |
I have the CAI with the Apex scoop ,works great in the Arizona heat .
if I recall Ted Janety did some tests on them. Is there any more recent tests of the new models around ?
