12-13-2020, 07:28 PM | #1 |
Onyx_Z7 <— Instagram
Drives: 2013 2ss 1le Join Date: Aug 2014
6 bolt block and headers
Okay guys getting closer to getting my dart shp block and I need some help on figuring out what headers will work with a 6 bolt block. I will be going with AGP twins later on so it’s either stock manifolds or shorties. I already have some aftermarket prc 260 6 bolt heads and will be using arp head studs. Would the stock manifolds work with a little modification? Or am I gonna have to fork over the extra cash for some shorties like arh or Doug thorley headers?
12-13-2020, 08:17 PM | #2 |
Drives: G8 Join Date: Mar 2012
Huron Speed make manifolds which clear the 6-bolt heads. Stock position outlets which will work with the AGP kit.
Sent from my Pixel 4 XL using Tapatalk |
12-14-2020, 04:06 PM | #3 |
Drives: 2009 ZR1 Join Date: May 2010
Yes, the stock manifolds will work with modifications. They need clearanced and welded back up where the 6th bolt holt would hit them. Basically, grind enough clearance in which means you will make a hole, then have the hole welded closed.
12-15-2020, 08:48 AM | #4 |
Okay thanks guys!
12-15-2020, 09:03 AM | #5 |
As far as design and flow go which header would be good for twins? Huron speed headers or arh?
12-15-2020, 11:26 AM | #6 |
Whichever one you like best. If I recall, I think the ARH are equal length but I don't know how that plays out in the real world.
12-15-2020, 12:15 PM | #7 |
No Tags/Habitual Violator
Drives: 2012 SIM 2SS/RS & z71 Join Date: Sep 2011
Those equal length headers will take up space if that’s any concern. Old school was equal length offered more to N/A motors than forced induction.
12-16-2020, 07:21 PM | #8 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
I got a set of BBK shorties that I ceramic coated. Going on my TT TMS 427.
More to come. |
12-18-2020, 09:56 PM | #9 |
12-19-2020, 06:58 PM | #10 |
Drives: 2010 Camaro SS Join Date: Jan 2015
I have a set of Huronspeed shorty headers that clear 6 bolt heads. I had them on my LSX427, they are ceramic coated. I'm going to be listing them for sale. The turbo kit is for sale also.
12-19-2020, 07:23 PM | #11 |
SomeguyK
Awhile ago I did a quick mock up and they seem to clear fine. Now you got me thinking and I may need to recheck. Lol
More to come. |
12-19-2020, 07:24 PM | #12 |
Drives: 1970 Pontiac Firebird L8T Join Date: Dec 2016
Do these have the recessed area where the fire ring fits inside the manifold at the collector?
12-19-2020, 07:40 PM | #13 |
12-22-2020, 10:02 AM | #14 |
Drives: Red Jewel Camaro SS Join Date: Mar 2014
I have been running the ARH for 4 seasons now.
No issues,but you would need ceramic spark plug wires,or you will burn up a wire or 2 pretty easy.
BTR LSX388,AGP Twin Turbo.6L90,GM 9.9" Diff.Fore Innovations Level 4 fuel system.Great fuel economy !!!! 1xxx RWHP
