12-30-2020, 06:14 PM | #1 |
Drives: 2011 Camaro 2SS/RS Join Date: Jan 2011
Am I missing a hose?
I went to get a smog check done today and the guy was about to fail me due to this hose/plug missing. I had no clue it was even that way. Luckily he still passed me, but does anyone know what goes here?
Thanks for any help! Allen
Allen
2011 Camaro 2SS/RS Last edited by dma05; 12-30-2020 at 06:17 PM. Reason: Add pics |
12-30-2020, 06:18 PM | #2 |
CamaroFans.com
I'm guessing you're having issues uploading a picture.
Used the Go Advanced button and then the paperchip icon to upload. |
12-30-2020, 06:19 PM | #3 |
Yea I was hahaha. I got them uploaded now. Thanks.
Allen
2011 Camaro 2SS/RS |
12-30-2020, 06:36 PM | #4 |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
Should be capped off. Here is mine
ECS supercharger, custom ground cam, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
12-30-2020, 06:43 PM | #5 |
CamaroFans.com
...and there you have it... |
12-30-2020, 07:00 PM | #6 |
Drives: 2010 SS Camaro Join Date: Oct 2008
That is part of your PCV system and there should be a black vacuum line connecting this to either your intake manifold at the front of your vehicle at or near the throttle plate or the air plenum coming off of your air filter going into the throttle plate. If you have an aftermarket air filter could be that someone just forgot to hook it back up. If its not throwing any codes or causing a rough ide you can plug it or look for the other end that's open like I talked about earlier as this is where the rubber line plugs into that I was talking about. Hope this helps and good luck.
12-30-2020, 07:11 PM | #7 |
Drives: 2012 Camaro SS Join Date: Dec 2019
Pretty sure that’s where I hooked up my catch can too. Should go to the intake
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
12-30-2020, 07:12 PM | #8 | |
CamaroFans.com
Maybe the car had a catch can that was removed or something |
12-30-2020, 07:41 PM | #9 |
Drives: 2010 camaro 2SS/RS M6 Join Date: Sep 2014
Powdered coated my valve covers today and it's capped from the factory. 2010 Ls3
Texas speed F-35 cam, rollmaster timing set, melling hp pump, ls2 chain damper, fluid damper 25% under drive, Che rocker bushings, tsp .660 lift valve springs, BBK CAI Amzoil filter with Phastek ww relocation and scoop, Gmpp axle back, Speed engineering 1 7/8" LT's no cats, Peak speed shop ported tb, NGK tr6, MSD wires, Amsoil Zrod wix, heritage grill, 1.25" BMR springs, MRR 228, Nitto Nt05,dyno tuned by complete street performance, elite eng catch can, clean side separator, Hurst shifter, Zl1 addon wickerbill
12-30-2020, 07:53 PM | #10 |
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro Join Date: Oct 2013
The LS3 is capped here. I believe the L99 has a hose attached as part of the PCV.
12-30-2020, 07:54 PM | #11 | |
12-30-2020, 08:17 PM | #12 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
Same here. 2010 L99 and I had a factory valve cover vent
12-30-2020, 09:10 PM | #13 |
It's up to you wont hurt anything if you just plug it, I have forced induction on my 2010 L99 and yes I use that vent as well for my catch can. I'm sure like some of the other folks have already discussed here some are plugged off and some are being utilized like I stated earlier. My car is an early model 2010 that i got in June of 2009 and the vent on the drivers side of the valve cover was being used to vent vapors as I explained in my first post. Either way I think you'll be fine if you want to plug it off. If you notice in your picture it is dirty at the base of the vent this is because the oil vapors coming out of the vent tube are wet and dirt is being collected at the base of the valve stem. Like I said no big deal just plug it off sir.
12-30-2020, 10:41 PM | #14 |
As someone else said, from the factory the L99 uses that port for a PCV line, while the LS3 has it capped off and pulls from the valley cover port. As long as you are running either one for a complete PCV system you are fine. But I would definitely be running one with or without a catch can.
