03-13-2021, 06:59 PM | #1 |
Drives: 2010 2LT/RS Join Date: Sep 2017
Lug nuts fit SAE sockets only, not metric
Hi all,
I was just wondering if anyone else has ever found their OEM lug nuts had issues with fitting a 22mm socket? I've always used a 7/8 until recently when I was gifted a 22mm socket and to my surprise, I found that it wouldn't fully seat onto my lugs. It would go in a bit then stop. However, my 7/8s fit perfectly fine with the tiniest wiggle space. I've been told that the lugs have been metric since the early 2000s but this situation has definitely confounded me. Cheers! |
03-13-2021, 07:01 PM | #2 |
Drives: 2014 1SS/1LE Join Date: Nov 2015
I had to buy a thinner wall socket to fit my wheels but I'm pretty sure it's metric.
03-14-2021, 06:03 AM | #3 |
Drives: Two 1984 Z28 / 2014 2SS/RS AGM L99 Join Date: Feb 2021
I used a 7/8 as well and I just pulled and polished all of mine .
03-14-2021, 07:44 AM | #4 |
It don’t come easy.
The difference between 7/8” and 22mm is approximately .010”. My guess is the reason you can’t fit the 22mm socket on the lug is from slight distortion from prior use of a SAE socket. I wouldn’t have any concern using a 7/8” socket.
03-14-2021, 09:57 AM | #5 |
This is exactly why I can fit a 22mm on some of mine without an issue, but the others give me a hard time.
03-14-2021, 05:27 PM | #6 |
Drives: LT W/2LT,blue metallic Join Date: Jul 2016
wierd...i use a 4 way lug wrench on mine no problem
03-14-2021, 06:45 PM | #7 |
Same here and isn’t it 13/16” might be wrong.
Life is short, drive it like you stole it! |
03-14-2021, 11:55 PM | #8 |
Yeah that might be it. The ridges of the lug are a bit flatter per say vs the ones that fit the 22mm. The flat sides fit the 22mm socket fine but its the ridges that have issues fitting. I wonder if the ones that DO fit my 22mm will deform more over time to the point where it won't fit anymore...
03-15-2021, 08:52 AM | #9 |
Drives: too many to say! Join Date: Nov 2010
The nuts with the stainless cover can get damaged and cause tight fitment. Use of an impact gun is a leading cause of the damage
03-15-2021, 09:17 AM | #10 |
Started#gottalovethatblue
Softly off topic, but it was the first thing I thought of...
