03-21-2021, 03:08 PM | #1 |
Drives: 2016 Chevy Camaro 2SS Join Date: Sep 2020
Stock Subwoofer Question
Is the stock subwoofer on the convertible connected to the stock amp if not is it possible to have it connected to an aftermarket amp?
03-21-2021, 03:13 PM | #2 |
And could I replace the factory 10 inch sub with an aftermarket 10 inch sub
03-21-2021, 05:22 PM | #3 |
Drives: 2013 zl1 vert Join Date: Dec 2018
It is powered by the factory amp. You can replace it, but you’ll have to cut the factory connection off to hook up a new sub. The factory amp is not powerful enough to push a aftermarket sub. I did a kicker free air sub in the factory spot with a alpine 5 channel amp. Not going to win any competition but it’s good enough for me at my age now.
22% lower/ 2.5 upper/ 2 headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ RPM 5 intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2 lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
03-22-2021, 05:19 PM | #4 |
Are the 4 speakers also connected to the factory amp? Also, the stock sub is 10 inches right?
03-22-2021, 06:00 PM | #5 |
yes and yes
03-23-2021, 09:05 AM | #6 |
Drives: 2012 SS L99 Converible Join Date: Mar 2016
No the amp in the rear is for the sub only
2012 L99 Convertible SS
Tooley Racing Stage 2 DOD delete, 3,200 stall converter, Shorty headers and custom stainless exhaust, CAI, and tune as mods |
03-23-2021, 09:34 AM | #7 |
Ok I’m a little lost Bc I have two of you saying something different. Will I have to connect the 4 speakers to the amp? Or are they already connected to the amp?
03-23-2021, 11:37 AM | #8 |
They are connected to the amp already
03-26-2021, 03:28 PM | #9 |
Also just to make sure I can fit a 20 inch sub in the back.
03-26-2021, 03:50 PM | #10 |
Also what mounting bracket did you need for the new subwoofer
04-13-2021, 08:12 PM | #11 |
Drives: 2012 Camaro SS Anniversary Join Date: Sep 2015
I just finished replacing all speakers (10” sub) and added 5 channel JBL amp. One channel dedicated to the sub. I left the factory head unit for now. I recommend the the factory amp replacement kit from ********. Makes wiring super easy! I’m not sure where you plan on mounting a 20” sub. I mounted a replacement jbl sub by drilling new holes in the stock housing. You would have to do quite a bit of cutting to add a 20. Not sure you would need it either, but just my opinion.
04-18-2021, 08:57 PM | #12 |
Drives: Camaro SS Join Date: Jun 2020
Sorry for the hijack but I didn't see anywhere else that had this info.
If I've installed a ******** box in the trunk, does it benefit me (other than weight savings) to remove the stock sub from behind the rear seat? I'm not sure how sound works and if having the stock sub still there (but unplugged) would help or hurt. |
04-19-2021, 04:54 PM | #13 |
Drives: 2015 Camaro Convertible Join Date: Jan 2015
Where is the amp located ?
Can you replace the amp without taking the radio united out ? Do you access the sub though the trunk or just by taking the backseat out? I actually just posted to try to find out how to take back back seat out: https://www.camaro5.com/forums/showt...4#post10995744
2x 2015 Convertible 1LT
- White on Black 22s - Silver Stock |
